New Trek Speed Concept
Out of interest, which tririg product did you try, and what didn’t work? I have a set of the second gen Scoop Ultimate SLs. I was thinking of trying them on my bike when it arrives..
Ultimate Eco arm cups: they got me the reach I wanted, but the set up was not clean looking at was heavy, also had a lot of flex in the system. I do love a lot of tri rig prod but this one did not work for me. The evolve aero front end has been fantastic. I came up a touch with the evolve front end and going over bumps no flex.
When you say you didn’t have the reach with the stock setup, was in pad-reach or was it extension-reach you needed?
Never liked the stock pads so had switched over to 51 speed shop pads immediately, I was short on reach with stock set up. What I would still like to see from trek is making things easier to adjust day to day or like from training to maybe your want to drop 15mm closer to a race, other company’s are doing this so why cant trek?
Am I correct in saying that the ‘native’ rotor size for the current model is 160mm? I thought most bikes were built around 140 and then you used a spacer if you wanted 160. But the SC is built for 160’s? Will be using SRAM brakes if it matters…. Thx!
EDIT - OK I was confused as they seem to stock the full bikes with 160, but looks like that is because they ship with an adapter plate installed?
