New swimmers and panic attacks
Have any of you dealt with this in the pool?
I have a fairly new swimmer and she is having some issues with keeping her face in the water and not panicking. If she’s in a lane by herself with no one around her, she does better, but once she gets into a lane with others (even only 3 or 4 total in the lane) she has trouble. She can actually swim (stroke-wise), but she starts to hyperventilate and then everything falls apart.
Thoughts? TIA.
clm
tanker has trouble putting his face underwater - he’s here at my office at the moment, so i asked him how he deals with it. i do know he keeps his stroke rate REALLY high, and isn’t comfortable swimming at lower cadence, because it means more time with his face submerged.
he says he keeps his eyes closed whenever his face is in the water, despite wearing goggles - the “if i can’t see it, it isn’t happening” mentality - and just holds his hand out when he knows he’s getting close to the wall so he doesn’t ram it with his head. however, he also said that by the end of 25m, he’s starting to get pretty anxious and stops to breathe a bit (while hanging onto the wall) to calm himself down before doing another length. i can’t say as i’ve ever seen him to 2 lengths together, which is definitely an effect of the anxiety as he knows how to execute near-flawless flip turns. he also says that if he was in a 50m pool instead of the 25m pool we swim at, he wouldn’t have a problem doing full lengths - he takes every opportunity to hang onto a wall, but wouldn’t have to stop mid-length to calm himself down.
he also said he only breathes out through his nose (inhales through the mouth), because if he gets water in his mouth he’ll “know” his face is underwater.
cheers!
-mistress k
I’ve always told people that I help in the lake to count their strokes. It has them focus on something specific and seems to work pretty well.
Thought #1: She should not, under any circumstance, enter a triathlon. Until this is under 100% control, she should not be entered into a mass swim event.
Thought #2: I worked with a boy this summer who has a sensory processing disorder and had the same problems as your swimmer. Good swimmer but would panic at times. His was caused by his brain’s inability to process the changes in his senses when he was swimming. He could swim underwater and be fine, but on the surface, he struggled.
Anyway, Drill progressions were what worked the best. I had him for 10 weeks and all we did were drills. His best improvements came when we were able to work through some very easy drill progressions.
Example:
Drill 1: Bob’s
Drill 2: in the deep end, Doing a bob to touch the bottom with the feet.
Drill 3: Being able to kick on back with good body position:
Drill 4: Being able to kick on stomach, hands at side, until breath runs out. Stop
Drill 5 Kicking on stomach with good body position and rotating the body from side to side
Drill 6: Kicking on the stomach, hands in front, press down and lift head for a breath.
Drill 7. breathing to the side…
you can see where this is going. SMALL steps. Breath control, comfort in the water. Give her something she CAN do without panic, and build slowly from there. Give her control of the swim.
I’m not a huge fan of group swimming to begin with, but she is a great example of someone who need to have her space first, gain control and slowly ease into being able to swim with others. Sink or swim (pun fully intended) ironically doesn’t work that well in swimming.
The boy I worked with ended up dong very well and even won some ribbons at some of our meets. He went from not being able to swim more than 5 feet without grabbing the wall to swimming 50’s freestyle and backstroke with form good enough for a 7 year old WITHOUT the disability.
great progression video…
http://www.youtube.com/watch?v=vmVfXk18AWY
Things like this will put the power back in her hands. A snorkel might be a good idea too.
Working on exhalation into the water - not holding their breath - can make a massive difference for swimmers.
Starting them exhaling into the water whilst standing and bending forwards will help them get used to it. Then progress to sink-downs in progressively deeper water - sinking downwards vertically whilst exhaling. Getting into this habit of exhaling into the water has a massive effect on relaxation. After the sink downs, ask them to swim a lap and and simply focus on a strong exhalation into the water.
See our tip 3 here: www.swimsmooth.com/beginnertips
Also all the advice on exhalation and sink-downs here: www.swimsmooth.com/exhalation
Hope that’s useful. If you try this method then please let me know how it goes!
I like the work of at www.conquerfear.com. I use aspects of their work from the book and video a few times each year.
The general idea is not a shocker, gradual exposure to the environment; pretty standard stuff for getting over fears. There’s also the bit on staying internally focused. But having a well defined progression is good. Also don’t overlook the necessity to make sure the person is completely comfortable with one step before moving on to another.
In my experience it is rare that the person is indeed truly fine with phase one but panics in phase two. So while she is probably OK swimming in her own lane, she is more than likely uneasy with that as well.
Also, I have found these folks benefit most from getting to the pool often, 4 times a week or more but staying for a short time. If they don’t really like to swim then this is usually an issue in that something always comes up and they can’t get to the swim.
Thought #1: She should not, under any circumstance, enter a triathlon. Until this is under 100% control, she should not be entered into a mass swim event.<<
I totally agree.
Thanks much for all for the tips and drills. I’ll have the entire lane 1 work on them.
clm
yeah,
as with most things
to get better
you do it a lot
even if it isn’t pleasant
