https://blog.stryd.com/...lw8VxojKtTYCKX8_o2L8
What does the new Stryd do?
The new Stryd is the first tool built for runners to measure the wind. Stryd reports the extra power (in watts) required to overcome air resistance. Now, you will know how much power you need to run into a headwind, the power saved when running with a tailwind, or the power saved when drafting off a pack of runners. Stryd gives runners the ability to turn the wind into a measurable and performance enhancing force.
What else is new with the new Stryd?
**- World’s first wind capturing capabilities **
The entire pod structure (including the clip), has been redesigned to capture wind. The external shell, and internal components have been designed, specifically to capture and analyze in real-time the air and wind you are running through.
**- Next gen motion sensor **
Next gen motion sensor delivers improved accuracy
**- Newly added environmental sensors **
Added temperature and humidity sensors will enable you to use the environment to your advantage.
**- Newly added magnetometer sensor **
Added magnetometer to enable several new and exciting planned-for capabilities, including improved accuracy.
**- Greatly expanded storage **
64x expanded storage in Stryd will enable longer data collections for your ultra running as well as much higher precision data collection.
**- New, high visibility charging & pairing indicator **
Stryd’s new LED makes indications, like charging, completed charging, pairing, and wireless connections are clear and easy to see, even in sunlit conditions.
**- Friendly pod and clip experience **
Stryd’s clipping and unclipping action is super smooth and effortless while being just as secure as before. Switch Stryd between shoes is a breeze.
**- Increased antenna range **
Stryd’s antenna range has been greatly increased so you can rely on each and every data point coming through, whether to your phone or sports watch.
