Rumor on ST and several websites is the GPS units inside (SRiF vs new Garmin) the 10/15 220 620 and fenix2 etc are not as accurate as the 310xt 210 910xt seems to make sense since Garmin changed the guts in the watches from SRiF. Don’t take my word for it type in fenix2 in our ST forum or even google 220/620 and accuracy.
So question is did DC rainmaker not catch these things or did Garmin send him a special unit. I really like and trust DC rainmaker but why would issues be all over the place on ST and the web and not a word on DC’s website?
Maybe I am wrong but the seal of the deal for me was REI selling the fenix2 for 100 dollars off retail with HRM or not. Why else would rei sell a less than a year old product with all the cool gadgets for 100 off.
I figured this was worth discussion on here I just went through months of research before moving to the 910xt. It makes sense that the inside would cause differences.
I put this up not to attack Garmin but to find out what is going on and to help our fellow ST folks.
what evidence have you seen that the 220/620/fenix2 etc are less accurate to any substantive degree?
Same 2.5 mile OWS that was measured independently.
My Fenix2 measured it as 3, 3.5, and 4 miles on three different occasions.My 910XT meaured it exactly 2.5 miles twice.The Fenix2 has many problems, just one of which is poor accuracy in OWS measurement.
Would be interesting to plot the data from each, might lend a clue as to the source of the error
All swims were done with the watches on my wrist. Based on vibration feedback that notifies when the GPS signal is lost, the Fenix loses the GPS more frequently. I assume the algorythm for filling in the missing blanks is better on the 910. But, the 910 loses the signal less frequently as well.
The Fenix is so bad, it showed me swimming deep on land at times.
It also made a mess of my Challenge AC swim, missing an entire section (maybe a quarter to half a mile) of the course.
This, on top of it getting water inside on two different watches, and I sent it back twice and have been using my wife’s 910 while deciding what to replace it with.
Depends on the source of the error - a precise but not accurate unit would likely be getting the correct input from the satellite and muck up the conversion in the software, whereas a unit that’s all over the place is likely calculating it’s relative position incorrectly.
I’ve had a 220 for a while now. It definitely stops me at the same spot each time in my 2 and 3 mile runs.
Of course it could be consistently wrong =)
Same here, my 220 alerts me for splits so consistently on my regular routes that I know when it’s going to vibrate within a 5-10 foot window. KM 1 is as I run by a speed limit sign, #2 is as I go by a certain tree, #3 is in the last 10 feet of a parking lot. Before that I had a 305 and it alerted me in the same exact spots. I’ve not used a 310/920 to compare.
For instance, I use my 910 for every run I ever do, easy, all out, temp, etc. I have it set to give me a 0.25 mile split constantly. There are a few odd ball things that very consistently happen.
First, there is a place in my neighborhood, where no matter how fast I am going, how I am feeling, that quarter mile is always way slower than the one before it and the one after it. It is like the signal is blocked and it thinks I run a shorter distance over the same time period in that one spot.
Also, when the thing is first getting going (even if it has 20 feet accuracy noted or less), it will always predict that my first quarter heading north is longer than the same distance and same location heading back south.
I only point all this out to say, there are some oddly consistent inconsistencies ( inside that 910. All in all, I wouldn’t ever trade it. Love the watch for swim/bike/run for sure.
It looks like the problem isn’t the accuracy of the different units, but the quality and this really only presents itself in OWS. when running, the units should always have a decent GPS signal and should all have the same accuracy. But when OWS or perhaps trial running or urban canyon running the units will lose the signal. the ones that maintain the signal longer and pick it back earlier will give much better results. For those conditions, the algorithms are also critical in generating accurate tracks and weeding out the bad data.
Yeah I can see how water would present extra challenges, and maybe also the movement of the arms.
Also could vary depending on stroke rate? Higher rate = less time to get a signal fix? Then again it could be the reverse that the faster turn over of arms leads to less loss of a signal. Surely there is a TTL (Time To Live) on the signal for these watches before it considered the signal lost?
Funny that you mention this. As I’ve been doing more speedwork, I’ve gotten the feeling that the 220 just isn’t as consistent as my 610 and I’m thinking about switching back. It’s too bad, because the 220 is a MUCH more comfortable watch. The issue I’m having is whether or not the 220 is “good enough.” I mean, when I run in hilly canyons, my pace is not that much of a concern to me. It’s on the open road with a clear view of the sky - most of my races and speedwork runs - that I value accuracy the most, and these are also the situations where it’s most easy to be accurate.
But yesterday, doing a long tempo run on tired legs, when my RPE:speed is least accurate, I felt like I wasn’t getting an accurate picture of my run. Like my RPE:speed is whacked, but the watch was even more wacked.
In general, I’ve felt like the 220 is “good enough,” and the comfort is worth a lot over the 610. But on some of my runs, it’s becoming more of a concern as I feel like I’m really not getting an honest picture.
Honestly, I thought I was crazy. I had seen some grumblings about the 220/620 accuracy, but that was before a lot of the firmware updates. Had no idea that had stopped working with SiRF. That is a massive disappointment.
But I definitely felt like I was “that guy.” I mean, who blames their GPS? But maybe I actually wasn’t so crazy…
I’ve got another tempo tomorrow. Maybe time to throw on both watches and see what I get.
There are other head ot head comparisons on the garmin fenix2 forum on their own site.
It’s a well known phenomenon.
My own experience is that the fenix2 and 910 give very different results on the same swim. The fenix2 jumps so much that it gives extra distance to every swim. The reading jumping forward and back along a path won’t change much since it will average out. But the side to side jumps perpendicular to the true path add distance.
I’ve put nearly 500 miles on my FR620 this year & I haven’t had any of the GPS issues that some have claimed. All of my tracks have been spot on. The only issues I have had are the widespread ones when new software was released and occasionally the watch will take longer to lock onto the satellites, but never an issue with accuracy. I hit my mile marks on consistent tracks in the same spot every time.
I believe that there are two possibilities; either there is a QA issue at the point of manufacture & they are letting bad units out in massive numbers alongside the good units & the customer is getting the luck of the draw, or people’s negative opinions are being fueled by posts like this one and the review most often quoted by fellrnr that calls Garmin’s GPS out.
Garmin recently reduced the price of the fenix2, REI is simply reflecting that change in price. The question to ask is why Garmin reduced the price, is it to move product at the end of the season? Move a product that is perceived to have a lot of issues? Prepare for a 910 replacement?
I have both the 910xt and Fenix2. For running they seem to agree on the distance within a small variance (under 0.1% difference). Swimming is a different matter, the 910xt seems more consistent than the fenix2 with the fenix more likely to over state the distance or report odd swimming behavior (doubling back for 50 yards or swimming over land at 5mph), I think this is more of a software issue but that’s just a guess on my part. There are times with both units when it records crazy data, running over buildings, moving at 30+ mph, swimming over land, etc…
I think DC rainmaker reports accurately based on his experiences, but he is a small sample size which means he won’t see every problem. Some of his reviews include problems he experienced. Garmin ships a lot of units, some of them are going to be bad even if the defect rate was 1 in 1000 there would still be many posts on the internet complaining about them. My n=1, I’m on my third 910xt (in two years) having had a variety of issues a quick search shows many people have also had to have repairs or replacements with the 910xt, I’ve had the fenix2 since march and its running strong.
The team that handles the fenix2 is much better about software updates to resolve issues than the team handling the 910xt.
Well he’s going to miss a few things.
The biggest mistake I think I have ever seen him make was missing that the speeds recorded by the timex global trainer were off by about 25%.
The total time and distance make sense, an average of 24 miles per hour. But look at the speeds in the graph, the green line, according to that line he hardly ever got over 24 mph and spent most of his time at 18 mph. If you were able to highlight a section, like trainingpeaks allows premium users to do, the speeds for that section would be off as well.
As far as I know, that was never ever fixed on that watch incidentally.
Even for an extensive test, there are things he is going to miss, Ray seems like a good dude and does the best reviews out there; but he’s not infallible
The issues with the fenix are subtle enough that I can easily see where they would go unnoticed for the two or three weeks he used it.
