Brand new crank I took off my new Specialized Crux cyclocross bike. It is a BB30 bottom bracket, (no bottom bracket included)172.5 mm crank arms, and a 46/36 gear range. You can switch the rings if you like. If you want, I can put a set of Sram Force rings on it with a 50/34 compact gear on it for road or tri use.
I will not charge anything different, just let me know which rings you want, either the 50/34 or the 46/36.
Rock on! Happy Holidays!
