In it they show the IA, the current DA etc. However, at some point they show a quick close-up of a DA. At first I thought they forgot to assemble the front brake. However, closer inspection shows an integrated brake with a cover similar to the IA, and the front brake cable entering the stem. This could be some changes for the next model DA!
What do you think, could this be the new DA? It is said to be announced in two weeks. Is this what you want in a new DA?
Are there plans to make the Felt FRD compatible with mechanical Groups? I use Red22, it is my preferred group and from what I understand it can’t work on the FRD. Correct me if I am wrong
I don’t think I will be drilling holes in a $3000 frame. There would also need to be some sort of Bottom Bracket cable guide installed, and methods to secure cable ferrules to the frame so the cable housing doesn’t slide into the frame.
Thanks again
The IA FRD works just fine with Red22. This is exactly how Rinny set up her IA to win the World Championship last year.
-SD
SuperDave can correct me if I am wrong, but FRD stands for Felt Racing Development and covers the IA, AR, and F if not mistaken. It is used to designate basically the bikes that incorporate UHC Nano TeXtreme® development at this point I believe.
Not talking about the IA. I asked about the FRD - a road bike.
