Apparently run by Movistar during TTT at the tour (see 6min in vid below) . Hopefully their performance doesn’t reflect the tyre, but if they do a tubeless version then it could be a contender for fastest tyre.
https://youtu.be/uB71wxegDAk
We’ve had some and they feel really thin - almost as if a Conti Supersonic (the old one) just had a GP4000 tread stamped on it. We were told Conti reckon the 4000 tread is more aero than the 5000 tread - not sure how they did their testing but when we did it the 4000 was quicker from 0-5deg yaw then the 5000 was better (and using a weighted drag calculation overall the 5000 was better).
Interesting. I assume from that they are clincher only?
Yeah clincher only from what I understand.
The real question is how well they will work on your wheels? Are these likely to be faster than the Corsa Speeds from a CdA+Crr perspective?
Looks like the tire we’ve seen on Frodo & Kienle’s bikes for awhile now (over a year iirc?).
If they are (and they’ll be available to the general public) we’ll definitely be letting people know!
When has tubeless proven to be faster?
Conti always has special tires available only to pros. Does not mean we will ever see this available to the public.
GP5000 and Corsa speed… both measure lower rolling resistance as tubeless vs running as clincher.
https://www.bicyclerollingresistance.com/road-bike-reviews
BRR tests with butyl tubes. With a latex tube, tubeless is no faster.
stand corrected. Not seen a comparison recently since his previous.
did they mention a release date by chance?
Don’t they have to be publicly available in the next 6 months, as per the UCI rules?
Unfortunately not - this was via a third party rather than Continental themselves.
Maybe true. But running at lower pressure is a hell of a lot more comfortable for both training and racing. My brick runs since switching to tubeless feel noticeably fresher, and on longer brick runs I haven’t been getting the dreaded cramps I used to get between my shoulder blades. I might be trading a couple watts running 75-80 PSI vs 90+, but I’m pretty sure I’m going to make it up on my run split.
If the lower pressure is more comfortable, there’s a good chance that it’s also faster. Discomfort from surface irregularities is fueled by energy stolen from your forward momentum.
That said, I don’t get very concerned about road riding with fairly low pressures in tubes. I’ve only pinched a tube on the road once ever.
I’ve been riding on our crap roads with 75psi (23mm front, 25mm rear) and latex tubes. No problem.
The only time I’ve pinch flatted a latex tube in several tens of thousands of miles, is when the tire sidewall also failed.
Don’t see the point of tubeless personally, unless maybe you ride through goatheads all the time or something.
Apparently not. Conti has been making tubulars with latex tubes for the pros for many years, and these have never been available to consumers. Plus I recall a few years back when Martin used a prototype GPTT without the Vectran layer. Never seen that available.
So are we thinking this is the “old” Conti Supersonic mold with the GP 4000 imprints?
I was thinking about using my new old Supersonic 23mm for Kona this year… I’ve been saving it for a special occasion… but if they’re re-releasing it as the TT Pro LTD then I can get that.
9/10, well done ![]()
