New bontrager rubber pocket
Does anyone knows if the new rubber frame pocket that comes with the trek speed concept 2014 is available for sale?
can it be adaped to an earlier model or to a cervelo p5?
If you’re talking about the Speedbox2 (mounts directly to toptube) that’s part# 436152 and it’s currently not in stock…ETA to warehouses is later in February, but that could change.
It’ll mount directly to any toptube with waterbottle-spaced bosses and sufficient clearance up by the stem/housing entry point into the frame. That means it does work on the original SC…though perhaps not as cleanly as on the new one since we matched the leading edge profile to that of the integral cable port for the new bike.
The P5 came out with SC-style toptube bosses but probably not with Bontrager accessory integration in mind…so I can’t say for sure if the new Speedbox will fit on that platform without modification…but it did occur to us to use slots vs discrete holes in case that boss idea had caught on since the first SC…so maybe.
thanks carl for your reply
