New Bars for Plasma 20
I’m ordering a new Plasma 20 and would like the be able to have a new set of aero bars for my fitting. I’m not finding a lot of choices so I was looking for some help. I was wondering wondering what the difference between the 3T Brezza and Ventus were, Im pretty sure the Brezza is lighter because it uses less materials but is about $200 cheaper. I also like the Shimano Pro Missile. Would any of these work with the Plasma or do you have any other suggestions? Do you think I should just try the different choices at my fitting?(Pro Missile not sold in shop)
p.s. I would prefer one with a s bend which I know the Ventus doesn’t come with…
Aluminum Vision base bar with clip ons. Anything else is just a waste of money and will not give any measurable performance gain. Even better is the stiffness of the intergrated Vision bar.
Chad
I know I’m not going to see a lot of performance gain but I’ve seen about 9 of those Vision bars have their extenders break off mid race. Looking for a little higher quality, like the cbx pro i would consider.
What’s an extender? I’ve been using Vision for years now without a problem and the roads around here are not smooth.
Chad
extensions*,sorry… they are two pieces and connect right outside the bracket and the piece furthest from the saddle breaks off in some cases. I’m sure there’s a million people that have used them without having a problem but when I come across 9 people who have had the clip on bust and I’ve never seen another model break on more than one occassion im probably not going to feel comfortable buying it. Obviously since you’ve used it and never had a problem your opinion is different, but if you knew 9 people whose profile t2 busted you probably wouldnt want to put it on your ride. Im sure the vision integrated bars are solid, never seen anyone have a problem with them.
