I am looking to replace the stock headset on this bike with something more aero and more solid. I am also not looking to spend 800-1000 dollars. What is a good match headset wise for this bike, and what is the difference between integrated and non? I appreciate it!
You sure you’re after a headset? AFAIK, you can’t spend $800-1000 on a headset if you tried, nor could you find one more aero than the other - because on the Felt frame you have no choice but an integrated headset. Each bearing sits inside the top and bottom of the headtube, thus it sees no air. Does this make any sense or maybe you’re thinking of a different part?
LOL! Ok, I am a dunce… I am also terrible about not knowing what anything on my bike is called!
Yes, I want to replace the whole front aerobar setup without spending a grand. I just replaced those rediculous brakes that came with it and the brake levers. Went with Cane Creek levers and Dura Ace brake setup.
I replaced mine with a set of Vision’s that I bought used here. They are commonly spec’d on a lot of bikes and folks like to “upgrade.” You can get them MUCH less than $800. Probably more like $100!
Are you able to angle-in the extensions on that bar?
You spread them apart or move them closer together, but they always are fixed parallel to one another. Is that what you mean?
Basically, I bought this bar and used the stock extensions. I went with a take-off from another bike because the Vision bar you can buy aftermarket is glossy with red letters. The stock bar is flat black with white letters and I thought it looked better. You have to buy it used though. Post a “wanted” add on this site and you’ll find one. They come stock with a lot of Cervelo’s and other bikes. People take them off right away. One man’s junk is another man’s . . . you know.
Great! Thanks for the help guys. One thing. I was thinking about going with these… I noticed that they come in different stem size options. Which is correct?
Chris
I’m no expert, but which one is correct will depend entirely on you and your bike! One has a 100mm stem and the other is 120mm. What size stem is on your bike now? That alters the “length,” or at least the reach to the bars.
I didn’t check, but they may have different widths too. That would be a measurement of how far apart your hands are when on the outer portions by the brake levers.
If you are unsure of your fit, you are better off with a non-integrated bar like the one I posted. Then you can change stems to the proper length.
I don’t, but you could also buy stems with different angles. Then you could use and flatter stem for sprint distance tri’s where speed is paramount over comfort, and use an angled stem (upward) for longer distance tri’s where comfort weighs a bit more. Others may say that’s not a good idea, but I’m not sure.
Well, I’m 6’1 and ride a stock 58cm bike. Is the stock stem 100 or 121?
I don’t mind not being able to reposition the stem to be honest. I think the width of this aerobar setup is roughly the same as what I have now.
The only other thing I’m unsure of is if I want those “s” bends on the bars or the standard ones that shoot forward and barely tip up. Is it that big of a difference?
Go figure, but according to Felt’s website the stock 58 has a 110mm stem!
I like the bends on my bars and find them comfortable for long rides. I’ve race 2 half ironman’s in them without any issues. On the other hand, there is a very good counterargument against them. You can read about it here.
