New aero brake from FSA!
https://farm6.staticflickr.com/5595/15089835671_8880e0367d_b.jpg
Higher resolution and other pics from the Eurobike 2014:
https://www.flickr.com/photos/65357593@N04/sets/72157646655335500/
They definitely do not have much tire clearance. On odd choice in this day.
Just spent a few hours rebuilding and adjusting the TRP brakes on my QR CD0.1. The rear isn’t as bad as some have described, but there is zero adjustability w/o using a hex wrench on the straddle cable mount. Ugh. The front is better, with some adjustment from the noodle. BUT, the multiple 2 mm / 2.5 mm hex adjusters are way fiddley and easy to strip/jump the adjustment range/have little or no effect. I hope that I won;t need much braking in my next race, as the TRPs probably won’t deliver - so a real concern. Happy for options and looking forward to comments…
I have a Paul Funky Monkey on the front of my CX bike. You may want to look into that for some adjustability. For the rear, just leave it open with just enough tension to engage at the limit if your brake pull.
The last picture actually shows what looks like 3-4mm extra clearance just because the brake-pads aren’t nearly maxed out. Seems more like a fork with the direct-mount posts too low, rather than a problem with the brake.
Nice but I too will stick with my Tririg since it looks cleaner aerodynamically.
and… aero brake with cabling as poor as a standard brake. Unacceptable. lol.
Compare the high point of the clearance to a straight line through the center of the pivots. The Tririg brake has a much bigger gap.
http://www.tririg.com/articles/2013_07_Felt_B2_Review/960/2013_07_Felt_B2_Review_55.jpg
