I have a stock Cervelo Dual Dura Ace that came with the 42cm Vision Flat basebar and TT Clipons. I’ve been using this for about a year but think I would be more comfortable if I could get them a bit wider, but the pads and clip-ons are already adjusted out as wide as they will go. It doesn’t appear that Vision makes a wider base bar, but maybe there’s a good clip-on that will allow me to move the elbow pads about a bit more. Any advice?
I think your best bet would be to change the basebar. Get one of the older round tube models from profile or syntace. The visiontechs are pretty wide already at their widest point so i don’t think you will get much help changing the clip-ons, though you might want to have a look at the easton aeroforce clip-ons.
Planet x ones are excellent.
I second the Planet X bars. The have a wide (excuse the pun) range of adjustment. Almost out to the drops.
Ric
Try the HED aero Bars, they are much wider. I had to get them because I am a little broad shouldered than most and it was a lot more comfortable. I had a set of Oval’s before and they really crunched me.
Given that the OP is riding a Dual, i’d hesitate to suggest £250 aerobars, especially since he might not like the new position after all.
To the OP: go with a cheap budget set-up first and dial it in. Once you like it, then if you want you can think about uber-expensive bars. FWIW, Bjorn Andersson rode with round-tubed profile design basebars (not sure what he’s using now).
A cheap round tube basebar can be had for $15-20 used, so why not give that a shot before dumping big money on something that might not save you any time on the road.
How far is that exactly? It’s not carbon and cool but you can adjust the Syntace C2’s fairly wide.
Amie AKA weaselgrl 'cuz I love all weasels including long-tailed & short-tailed martens, fishers, ferrets, sables and men!
It’s 9.5cm from the center of one pad to the center of the other pad. Here’s a pic of me on the bike. I just think I’d be a bit more comfortable with a bit wider setup:
And like one poster mentioned, I’m not up for spending $$$ on changing my setup. Maybe up to $100 max.
