Need swim advice
Alright I tried to focus and think about what I am doing. Here are some question, first I noticed that my next stroke right after breathing gets pretty much wasted, doesn’t feel I am getting any significant propulsion from that stroke and also destroys my momentum. Any drills to fix that ?
Second, Many times, I feel water hitting my belly during the pull, I guess this is a bad sign and means that my I am pulling in a wrong direction and losing the water that I have caught, am I right ?
Guessing that you are pulling your head up to breath, that will completely break your momentum…you need to rotate out to breath with your head down…as far as your stroke goes, would order the Total Immersion DVD, good place to start…you should not pull underneath your body…but alongside it while you rotate…drills have your thumbs brush your thighs…as you finish your stroke…just guessing here, you will know if it applies…
Many swimmers let their pulling arm slip under their bodies when they take a breath. Try to keep the pull wider when you breathe. You lose power if the arm slips under your body. When your body rotates don’t let the arm drop - have it extend forward.
-leh
