I spent a fantastic 3+ hours with PK Racing yesterday getting properly fit for the aero position(Christopher, if you’re watching, thanks for the outstanding attention to detail and knowledge).
Conclusion #1 was that I cannot get anywhere steep enough on my Cervelo Soloist (thanks to short femurs). I need a steeper seat tube, around 78 degrees, and a reasonably short top tube (i.e,. at least not a long one). I know all about Cervelos (P3, P2K), but I’d like to know what else is out there in that price range or less. I just need the frame/fork, so $1000-$1500, new or used.
Cannondale Iroman series. I have an IM 5000 and love it and I ride with a Thomson laid back seat post flipped to bring me to around 81 degrees. Straight seatpost gives you 78 degrees. Bike handles great even with the steep angle, much better than my converted road bike at least or my old Softride. Super light too, haven’t weighed it but I’m guessing around 17 or so with an old Zipp 909 setup. Top tube might be a bit long though so I ordered it one size smaller. I’m 5’10" and purchased a 54cm and it was perfect. For $1000-1500 maybe an IM 2000, same frame diff cranks.
Doesn’t the Soloist have a reversible seatpost that allows you to ride at a steeper angle (like 78 degrees)? Just going from memory on their website.
QR bikes have good geometry for your type (which also happens to be my type as well). Proportionally short TT (a 57cm frame has a 55.5 TT). With a zero-layback seatpost I was easily able to get 78 degrees.
How low do you need to go? Finding a steep bike is one thing, finding one that is steep and low is something else… Look at Ashburn’s bike that he posted the other day. Doesn’t get much steeper and lower than that.
So why look any further? P2K frames are showing up at very good prices on ebay. Now that the P3 is available in anaodized black and (drool) carbon, expect to see some good values on older used P3 frames over the winter.
With the seatpost reversed, it gets you to ~76.5 degrees. My hip angle is too closed with that. Surprisingly, on the fitting bike, at 78 degrees and quite a bit lower (I’m talking like 3cm lower than my previous setup) it was more comfortable.
I don’t need to get terribly low – most frames will work. But I do ride with a ~10cm drop on my road bike (which was more than I thought until we measured yesterday), and it’s an excellent fit.
I spotted the QR Caliente as a possibility. I think it’s 78 degrees. Wonder how tough it is to get repainted something other than that nuclear orange?
Well, because I’m annoyed with Cervelo, that’s why. I may well end up with another one (and I dig my Soloist). But if I can avoid it, I will. I just think their customer service is awful. Their emails regarding an obvious F up on their part have been curt and surly. I’ll give them another shot, though.
Caliente is 76.5 degrees (I’m sure most of the QR bikes’ geometries are the same). You could easily make it 78 just by pushing the saddle forward. Perhaps you can find a 2003 model - they were great looking (silver and black). I’ll bet you could find a frame/fork for ~$500 on ebay. Worth every penny in my book.
I’ll second the QR nod. It sounds like you’d fit their geometry great. You migth even be able to get a titanium TiPhoon Frame off ebay rigth now in your price range.
You may also want to consider a Softride. It would take a little more work, but you can set them up pretty darn steep. They are on major clearance right now, trying to make way for the new FasTT.
The seat tube angle does is not near the max effective seat tube angle. A decent rule of thumb is that for each centimeter you move your saddle for/aft you change your effective seat tube angle by 1 degree. Therefore, moving your saddle 2 cm forward would put you close to 78/79 degrees. Throw a zero-setback seatpost on there and you’ll have another couple centimeters. Getting far enough forward won’t be a problem.
As Ze Gopha said, consider a beam bike. As far as aeroness goes, they would be hard to beat with a double-diamond configuration. I think the Titan Flex sells a frame right about in your price range. I sure love mine.
You can always go custom. I got my aero frame from Russ Denny (http://www.russdennybicycles.com/). The web site isn’t much to look at, but get in touch with him.
He was great to work with and he can make it as steep as you need with a short top tube. I got my frame and fork in the price range that you wanted. Russ has worked with a number of high end brands, so he knows his stuff.
I’ve been wondering if there is a rule of thumb like that for the effective angle. Thanks for the post.
Where do you measure that from on the seat itself? Nose, middle, apporoximate location of your sit bones? Maybe take the exention of the seat tube line through the seat and then measure the distance from there to the middle of the saddle (or consider where you sit on the saddle as the “middle” of the saddle)?
Dan has a chart somewhere that shows the effective seat tube angle based on saddle height and distance back or forward of the bottom bracket (measured from nose of saddle). I believe it was on the old Cervelo site (may still be there). I’ll look around and post back if I can find the address.
