The Vuka alumina tested very poorly as per TriRig. I’d look into picking up a 40cm 26.0 Vision base bar and cutting off the upturns or the Felt Bayonet 3 base bar.
Pair either of those with the Hed Clip Lite or Zipp Clip ons and you’ll be set.
That ebay link says it is a UCI legal 31.8 bar. I have a older non UCI Vision bar I’m not using because it has a 26.0 clamp.
Zipp says not to use the Alumina Clip on a 26.0 bar. Wish I could, I love my Alumina bars.
I think the description on the ebay link is wrong. That vision bar is 26.0 (you can use the Vuka, but would need some shims) and non-UCI. It’s getting hard to find a 31.8 bar that’s not UCI 3:1. My Shiv Tri is a non-UCI frame, but they still put a UCI-limited base bar on it.
info from certain sources (singular) says the alumina on the vuka bull is not too bad compared to the vuka stealth, on the order of 20g drag with extensions,shifters and brake levers, but that is likely only zero degree. no, I don’t know the specifics, just the random info
Does the vuka stealth have an drag comparisons out there to a ventus or alpha? Haven’t seen any so curious as to what the thought was on its aero properties.
I don’t know, sorry. Felt is pretty responsive so just shoot them a question re stack height. You can buy the Zipp arm cups separately. It’s worth a shot as they’re super comfy and they’re pretty reasonable. If they don’t work I’m sure you’ll be able to flip them on the classifieds.
no clue, but I will be tentatively on vuka bull/alumina clip next season unless ins company settles by end of month. stealth is too high of a stack bar for me.
but do you really want to compare uci legal to uci non-legal?
I’m just open to options at this point. Trying to play the game of aero vs. DolLars. Is a vuka clip setup THAT bad to where it is worth I vesting in am alpha/ventus type setup?
I did not feel so, but I don’t have specific data on it vs other bars. but if it is only 2 w off at 30mph vs a stealth, that is good enough for me at this point. also like that vuka bull is textured, ie I don’t think any kind of tape/ friction surface will be needed for my TTing. plus it cost me well under half the cost of an Alpha
i’d prefer to still be using my aduro, but I don’t trust it after seeing more damage inside stem clamp area after further investigation from car hit in May.(peeled some carbon from steer tube too with insert)
impact with car turning right on red against the no turn on red sign at a multiuse path crossing intersection. you realize in hindsight how much such things really did affect you and equipment
