Need info on my Mavic SL tubular and my first Ironman 70.3
Im looking to purchase a couple of pairs of tire for my wheels and on my tires now the measurement says continental 27 inch 19 mm, can anybody tell me were I can those tires, I’ve never seen 27 inch.
Second question, I need to make a decision in the next 24 hrs, is timberman in New Hampshire a good Ironman 70.3 for a first event, I’ve never don a 70.3 ironman distance.
Thank you in advance
The true 27in. sizing went out years ago, I expect they are 700c. The 27in. / 700c sizing get used inetrchangeably at times, 700c should fit fine. The wheels would have to be over 30 years old to actually be 27in.
19 is also a very small volume of tyre too, ok for glassy hotmix roads, but doesn’t have much volume in case of road imperfections to prevent a pinch puncture…
pending the rims you have, and likely to help re availability, perhaps a 22mm might be better?
Worth considering anyway…
Good luck
Thanks for the tip, I will take that in consideration
700cc it is thank you
Do you guys recommend continental or vittoria?
