I’ve got a deposit down on the new Ellsworth Evolve, their first foray in to the 29ers.
I am going to build it up from the frame. My use of the bike will be XC riding and some racing, Xterras or MTB events as well as rides on local Fire roads etc.
I’m looking to go Sram X-9 drive train, and shifters, but not sure whether to go Grip shift or Trigger. I’m just not hearing a lot of good on XTR considering their expense. My LBO likes the Sram product.
I’m thinking one of the Fox forks with 100mm of travel (29er compatible). But not sure which model.
Disc brakes, and here’s where I get stuck, Mechanical or Hydraulic? Which brand? I’ve read up on most of the them, but can’t get a consensus. I want something relatively hassle free, I don’t like to tinker that much. And, need reliability. Weight savings is another criteria, as the 29er itself adds a little weight.
Well, if you are going SRAM, might as well get some Juicy seven hydraulic brakes to complement nicely. Sounds like you are spending some serious coin on this machine.
Yeah, it’s not cheap, but I could spend a LOT more. Basically, I want a “light” FS 29er, that will hold up for many years. I’m coming from a 12 year old HT, that is about 24 1/2 lbs., so, I’m probably going to come in around 26-27# on this bike. Hopefully, the FS and the 29" wheels will make up for the difference in ride quality etc. At 51, I’m tired of getting jack hammered on the rocky stuff.
Here’s the deal. I just started mtn biking again after about a 13 year hiatus. Kudos for going with a full suspension setup. I really wanted a HT for XC riding, but was talked into getting a stumpjumper FSR. Holy crap, new FS mtn bikes are sooo capable. I went for my first ride on saturday and I’m floored how impressive these bikes are. I have a vanilla 140mm RLC on the front with X-7 shifters, and juicy five brakes. The hydraulic brakes are the way to go. The x-7 triggers are fine, no problems. Also, get as much suspension as possible, at least up to 120, 140mm if possible (if the bikes geo can handle it). I’ve heard really good things about the fox talas. I have a fox float 120/130 that was switched out for the vanilla. I’ve heard good things about the float forks too. With all the new propedal, lockout, whatever settings, my favorite going uphill was full open the whole time. I only used the lockout for the front and rear while riding on the street. I actually think in technical ascents that the full suspension helps quite a bit. Downhill, these bikes are mini motorcycles. It is amazing the stuff you can descend on a FS bike at speed while on a HT you’d have rattled fillings and blurry vision (let alone a busted up bike). Have fun, that ellsworth is sick!
Thanks. I’m getting stoked for this baby. It still hasn’t been born yet, but I’m told they are coming soon. I think Ellsworth says 100mm is plenty for the 29er. I’ll check with my shop. Yeah, the Xterra Mountain champs in Ogden, kicked the crap out of me, really rocky and loose in places. I’d have given anything to have been on FS. Then at Xterra Nats in Tahoe, I was fine on the HT until the technical swithcbacks, once again wishing I could just let 'er buck, but could’nt do it on the old HT.
I thought Fox did have a fork or two for the 29ers. Guess I’ll find out.
X9 sounds good, I’ve run Rockshox Rebas (SL and Race), Marzocchi, and Winwood. Despite the crap (okay,personal opinion) that RS has put out in the past, the Rebas are a good fork. Another option that is more pricey, but has a loyal following is White Brothers. I’ve read nothing but good about the Juicy 7’s, but I run the Mechs BB7’s on my bikes, and they are great, except when forced to ride in the rain the stock pads wear really fast. (aftermarket “sintered” pads are the fix for this)
ps. Pics!
pps. more info than you can ingest over on the 29er board of mtbr.com
That’s the problem I have with the Mechanicals, we do ride in wet conditions a fair amount. If that’s going to be a limiter for the brakes, I’ll get Hydraulics. I thought people were in love with Juicy 7’s. No?
“I thought people were in love with Juicy 7’s. No?” Oh yeah, that’s what I was trying to say, but that I’ve not ridden them myself. The mechs are great in mud, but when it is really wet or raining and you get the constant stream of stuff thrown into the pads, they suck. I’ve worn through a set in a 45 min cyclocross race!
Sounds like a nice bike. I would make one point that the mechanical discs are pretty heavy, although they are easier to set up. I would suggest going hydraulics as once you have them set up they have much better feel and most importantly modulation. I found Avid mechanicals to be “grabby” and to have some difference in feel from front to rear, hydraulics make it much easier to control the braking.
I am running a Formula K24 set up right now and I am very impressed, they are extremely powerfull and the modulation is excellent. The only downside is they are a pain in the arse to bleed until you learn the technique. Regarding Avid Juicy’s I suggest going to www.mtbr.com and looking at the reviews online of the Avid’s. Some people have had no issues, but others have had a lot of problems.
Another brake to consider is the Magura Marta which is the lightest disc brake out there.
With such a limited number of shocks available I think it is a great idea for a 29er you only have a couple of shocks available and they are either very expensive or lousy. You can get a good shock that is state of the art for a reasonable price.
I was always dubious of the lefty until I bought a Cannondale Rush with one recently and I have to say that the performance is great. It is the stiffest fork I have owned, and I have owned Fox, Rock Shox, Marzocchi and Manitou. The stiffness would be especially noticeable on a 29’er due to the longer sliders. The main downsides are it is harder to take the front wheel off for transport (and you need a mount that takes the whole bike) and relatively few available hubs.
There is a special mounting kit to fit it to a non Cdale frame.
