Recently got a pair of Zero Gs. Got them mounted on my P3C and found out that the return spring is too weak to return the calipers after braking. Wonder if anyone has the same problem and if there is a fix for that.
Do you have a spring return on your brake lever?
Make sure your outer cable is the proper length, to slightly long (it provides some counter pressure). Also, don’t overtighten the central nut when centering.
Also make sure you don’t have a kink in your brake cable. Alot of times the inner cable will get kinked and you can’t see it. Pull it out and check to make sure it slides smoothly.
Jim
Sounds almost like a kink in the cable. The return spring for all I have ever seen only helps to keep the lever from rattling.
I’ve found that the common cause is poorly cut housing ends. Most cuts leave the end of the spiral metal protuding into the path of the cable. A second pass with the cutters (or a good pair of side cutters) can do the trick. Inspect each cut by passing the cable through before mounting the whole thing up. As other suggested, optimal housing length is also key. Weaker springs in brakes and no return springs in the levers leave a problem that wouldn’t otherwise exist on a road set-up.
Hope this helps,
GB
had the same problem on my front brae as you. Although it was only a Dura Ace brake. Loosen the main screw into the fork/frame depending on front/rear. Problem should be solved.
i had similar problem, emailed Zero G and they said they needed to fix them, they took them back. they were 05 models and sent me a free pair of 07’s with new brake blocks and cork brake blocks. Pretty sweet.
Thanks for the advice and to all you other guys too. Do you think it is possible that it is, at all, due to the bars I am using (Oval Concepts A900)? Was wondering if there is a particularly tight corner with the internal routing.
Yeah, it could be. The Zero Gs are awesome brakes (best out there IMHO), but they need to be set up right. Fine engineering for sure but … Since they have no return spring, the cable must glide smooth in the housing. So, tight turns, etc. can hamper return performance. I run Nokon cables with kevlar liner and silicone lube the cables when I set them up so you can make tight turns and braking is as smooth as butter and powerful with instant grab and no sponginess. If you are much of a wrench, I’d rec some Nokon’s for the brakes (no need for shifting as I don’t see much of diff really). Also, you save a little weight (hey, you bought some ZeroG brakes, right) ![]()
