Does anyone have any articles that describe the neuromuscular improvements from training at higher cadences on the bike? Not interested in any comparisons of sustaining power at high cadence vs low cadence. What I believe is that training at a higher cadence will improve your neuromuscular coordination, highlight any flaws in form (which show up as ‘bouncing’), and make you more efficient when you then reduce your cadence to your optimum race cadence. I need references for use in training “spin” instructors (in our spin format we don’t go above 100rpm, but most classes are predominatly 65-75rpm, so high cadence is 90+ in this context - I’m quite aware that there are other spin classes where they reduce all the resistance and hammer away with the heavy flywheel allowing them to handle 150rpm or more…we don’t do that).
It’s sort of like expecting baseball pitcher to improve his fastball by having him throw marshmallows really hard.
If you find any such references, they’re isolated cases. The literature just doesn’t support your assertion. I know that plenty of coaches do this stuff, since it has been passed down to them through the generations. But it really doesn’t work.
Although I must say that you don’t seem to be interested in the question – just interested in confirming something you have already decided is true.
I’ve been in spin classes where insructors do those high-rev sessions. They are pointless and do nothing to either increase a cyclist’s “efficiency” or aerobic fitness beyond what can be accomplished with normal cadences and normal work rates.
In order to improve the economy (the more correct term) of cycling, the work needs to be done at the contraction rates at which one will then go out and race. Doing low-power, 115-rpm spins will help develop the neuromuscular coordination to do low-power 115-rpm spins. But it won’t help a cyclist that races time trials at 90 rpms at high power.
Specificity rules here. If you want to overload the cyclist (essential for improvement) do it with higher work rates at race-specific cadences, not at artificially high cadences that will never see the light of day in an actual race.
Well, first of all, the people I am training, and the people that they are training, will never see a race in their life. I teach fitness instructors, who are mostly young women that also teach step, kickboxing, etc, who then teach the spin classes to, 90% of the time, people with limited to no cycling aspirations. Neverless, we do try to make it realistic to outdoor bike riding, which is why we don’t do some of the typical “spin” stuff you hear about.
The reason I want to work on higher cadence is as much for variety as it is for improvement. However, the instructors would like to know the “cycling” benefits of higher cadence work. These are obvious if you are a track cyclist with a fixed gear. And we have already beat the high cadence vs low cadence at a given power to death. Realize also that these drills are about 1 minute or so in length, repeated many times over a 50 minute workout.
Look at it this way. You generate more power at a given torque at 100 rpm than at 80 rpm. So to get to where you can sustain that torque x 100rpm combination for a period (assuming you can’t already), you can do three different things. 1. Train at the 100rpm x torque wattage for a shorter time period. 2. Train at the torque but a lower RPM for a longer time period. 3. Train at a lower torque but 100 rpm for the time period. All 3 are specific to what you are trying to accomplish and all 3 will help you get there. And there is real world benefit to being able to cycle efficiently at 100rpm, even if you don’t use this cadence for long.
If “the literature” runs counter to this, I’d be happy to read those articles as well if you have any you can point to. I’m happy to debate the issue if you like, but I sort of “need” the references, the debate would just be good fun. But the example I give above seems intuitive to me, and jive’s with my 18 or so years of triathlon experience, unsuccessful as it may be.
As for coaches, I know Troy Jacobsen does this a lot in his Spinervals. I also know that this is done a lot in other sports. Maybe not pitching marshmallows (imagine a 90mph marshmallow hitting the back of your mouth), but runners work on cadence, swimmers work on cadence. I know first hand that spending the winter doing all your indoor rides at 100rpm will smooth out your stroke and make you more comfortable and efficient at that rpm outdoors.
“imagine a 90mph marshmallow hitting the back of your mouth”
well put.
i know of no references for you. ashburn is probably right, you’re just going to get isolated anecdotes describing why training with high cadences worked for THEM. like, you know, lance for example.
training usually consists of motor learning elements and strength elements (among other things). one thing you’ll notice about elite long distance runners, they almost NEVER run at a lower than race pace cadence. even when just jogging 8 minute miles, they’ll usually be running at 95 or so cycles per minute. when they’re running, they’re also teaching. you can teach your body to run something under 180 or 190 steps per minute, or you can reinforce to your body the right way to run.
accordingly, i don’t see how it’s bad to reinforce high cadences, even when you’re going at less than race pace efforts. and, as race cadences for triathletes can be anywhere from 95rpm to 115rpm during a (short course) event, depending on tactical and technical issues, it seems intuitive to me to practice that.
I’m a spin instructor with experience training triathletes as well as your garden variety spinners, some of whom ride and some of whom don’t. I used to work for a Dan, so are you training spin instructors for a club near Bay Meadows?
Anyhoo, the trick is to stretch the comfort zone. If someone likes to ride at 90 rpm, make them push to 105 with bursts to 120, and the occasional “gonzo” to see what their max cadence is for 15 seconds. Yes, that helps improve neuromuscular responses and technique, if done with technique in mind. OTOH, if someone spins effortlessly at 150, they need to load up the tension (bigger gears) and concentrate on keeping the pedaling motion circular at 60-90 rpm.
Keepin’ it real (simulating outdoor riding) is tough to do. Most folks use easier pedal tension on a spin bike compared to what they’d need to actually do any kind of a ride. However, all things being equal, higher cadence means higher heartrate, and most spinners like that.
Just stay away from the wacky Johnny G, Schwinn workouts and remember to play good music (Filmore Rock, no techno).
There is a piece on pponline.co.uk which has a study of the effects of cadence on running economy post-transition. It does appear to be the case that spinning your legs faster into T2 will help you run.
It is not clear what the mechanism of the effect is, so difficult to draw conclusions about muscle damage etc.
Yes, I can admit there might be applications to cycling using high-spins as drills.
But,
This is why I think spin instructors shouldn’t do them. Fitness gains are about work rate, not leg speed. That is what stimulates the positive physical changes that people need (cardiovascular and intramuscular). And I think that people will stay in the high work rate sweet spot throughout a spin class by using the cadence ranges that people have self-selected throughout the history of the geared bicycle.
It’s better excercise, and is more specific to general fitness, to stick to cadence ranges that more closely approximate real cycling (which derives from real running). Physio 101 would teach anyone that a high HR is not the only goal of exercise. There are lots of ways to raise HR, and not all of them are good exercise.
I think the spin industry is mistaken in structuring these spin-as-fast-as-you-can workout cycles.
