Need Advice on best FRONT wheel for me
I weigh about 150lbs
During a Tri race, I average ~23 on a flat half IM course in low wind conditions (including mounting, turns, out of water warm up, etc.) so cruising speed is around ~23.5
I’l be racing Eagleman and Las Vegas 70.3 next year, plus some Olympic and Sprints
I prefer hilly technical rides for the shorter races that I do and have an aggressive ride style (cornering, downhill, getting through throngs of earlier waves, etc.)
I have a HED Stinger 9 FR as the rear wheel
So, for the front wheel, I am considering HED Stinger 9 FR (versus the Hed Stinger 6 FR or the HED H3) for front wheel, will I be ok with this the HED 9s in 90% of race situations (at what point does the HED 9 start to work against me versus the other choices)? What factors should I consider going to the Hed 6 or H3 on the front?
Depending on wind at Eagleman I would go with the h3. I was averaging about the same as you at EM but around mile 40 I could not keep up pace and it was all down hill from there.
Thanks - not I’ve seen many people with the 90mm on back and tri spoke on front. Is this a ‘normal’ configuration? Did you use the H3 at EM?
Stinger 9 all the way. It is super fast and comfortable. I have an '09 version that I’m trying to get rid of. The only thing I don’t like is that it is not as stiff as the zipp 808 fc.
I had the H3 and a sub nine on mine. I was humming and hawing about the 1080 but I decided against it incase we’re some strong gust. It turned outto be very calm that morning but the bike was already in T1. It worked out fine and I was happy with my choice. Though I was not happy with my performance after i cooked myself.
based on the fact that you say you are aggressive when cornering I think you will be comfortable on a 9 front 95% of the time.
the only time it works against you is when crosswinds scare you out of your aerobars (or crash you!)
put a disc cover on the rear and it will be even faster and more stable.
Curious why you are trying to get rid of the 09 version?
Thanks Jack, sounds reasonable
Hi Rick - what don’t you like about the '09 Stinger 9?
Nothing at all. It is a great wheel. Between the stinger 9 and 808fc it would be impossible for me to say which is faster without a trip to the wind tunnel. But, IMO the 808fc is just a stiffer more solid wheel. I feel more confident on it, and also think that the brake surface is better.
These are no doubt subjective issues and I know the new hed wheels have new hubs which may stiffen up the wheels. But I have ridden my 09stinger and fc back to back, and in my mind there was a difference.
Another selling point to me was that the 808fc is a clincher. That adds ease of use. With a gp supersonic and latex tube, my 808fc is within 50 grams of the stinger 9 tubie with a bontry rxl glued to it, so weight is a non issue.
Definitely get a front disc.
What has your durability been like on the GP Supersonic? Do you use it at all on the rear?
Not to hijack the thread (but here it goes), what wheel is best for the average circumstance? Flo’s 6 or 9?
I understand that having a shallower rim would be ideal in severe crosswinds but if the price is prohibitive, should the buyer go for a deeper rim and hope for a calm day? Or should they buy the deeper and just toss a training wheel on the bike, if need be?
Looking forward to any replies and sorry for the hijack
It’s a race day only tire, very good feel and no flats or wear issues yet. That said, I don’t have enough miles on it to have a strong opinion on its durability.
well in the case of Flo, the 6 is as fast as the 9, so that is an easy choice.
in general you need to ride some deep wheels on a windy day and find out what you can tolerate.
I ride a Stinger 6/9 setup w/ a wheelcover. How much speed can I buy switching the front to a Stinger 9? Also, doesn’t weight play into the decision? Is it reasonable for someone 135lbs to handle a deep front wheel?
Keep the 6 for windy days. Get the 9 for calm days… or to loan to friends ; )
  1. a little bit more speed
  2. not really
  3. my wife manages it fine at 135lbs. then again my 185 cat 1 friend can’t handle deep wheels at all.
What kind of conditions will you be looking to ride in most of the time?
‘most of the time’ - hmm; these will be race wheels, so expect primarily to use them at races and some tempo riding leading up to race day
Flat races tend to be windy; Hilly races tend to be a bit less windy.
I’ll use these on sprints through IM distance races, although I only have 3 half IM races on my schedule in 2012 (Eagleman, Vegas, and either Musselman or Providence) + Escape from Fort DE + USAT Olympic Nationals in Vermont + some Sprint races - both hilly / technical and flat
So, I can’t say I have a typical race, but Vegas is my most important race.
