Need a quick measurement
Would somebody please grab a tape measure and your 700mm wheel bike and measure 2 things for me.
  1. distance from the center of your axle to the edge of your rim in inches
  2. width of your dropouts in inches
Thanks, I’m looking at upgrading a 80’s steel frame and need to compare these. None of my tape measures have cm on them.
Just multiply your inch measurements by 2.54. That’ll convert it to cm.
This old frame is 6spd and 27in wheels. I’m looking for the measurements of 700 wheels and modern dropouts. Would like to converst to 8-9 speed and 700 wheels. I’m trying to figure out what I need to do to accomplish this.
  1. 13.5 inches
  2. 5 1/8 inches
Thanks a lot. appreciate it.
Just one question…maybe something to pay attention.
Weren’t the hub “narrower” in the past?
I believe I have seen this somewhere, and if this is the case, you might have some problems with new wheels and hubs!
"2) width of your dropouts in inches "
If your bike was an older 6/7 speed the rear spread is 126mm. On the newer bikes it’s 130mm. Upgrading to a 9/10 sp isn’t a problem as long as your frame is steel. 4mm isn’t much and the newer stuff will often just pop in fairly easily with no super effort. It it is more problematic a decent LBS can cold flair this for you. Sheldon Brown even tells you how to do this yourself on his website.
I was just over at sheldon brown looking at this. Also, the measurements given to me seem to be a little off. If somebody could double check cebter of axle to edge of RIM please?
Also this project is more about teaching myself bike mechanics than anything else. If I buy ebay or used I doubt I’ll spend more than a couple hundred on this. I think I am going with tiagra or 105 and barends on my drops for a shift set up. Found some brake levers at nashbar cheap. I am worried about the finding brake calipers that will reach 700 rims though.
Jim,
What kind of 80’s bike do you have and what are you trying to do to it. I upgraded a mid 80’s Miele last year from a Suntour 6 sp to Shimano 105 9 sp. Let us know what your intentions are and we’ll try to help.
Sorry i was editing as you were asking its on my post above.
Cerveloguy, its a Fuji Supreme touring frameset with Suntour 7 GT in the back and compe V in the front. Want to go 700 wheels, 9 spd and a triple in the front if I can. I may wait on the triple for now… I am gathering parts and info and will do this in the spring when I can get the race bike out.
This might be great timing My son and I are in the process of up grading our old steel (they fit perfect) Miele/Peugeot. We want to go to 9spd from 6/7 we live in a flat but rough area (kingston) Cost is an issue so wheels and der’s are all for this year. We live on our aero bars so shifters will be bar end. What kinds of problems will we encounter? What setup would be the best? Can we keep our biopace chain rings or will they have to go too?
All and any help is appreciated. Mechanically we more than competent.
thanks Rick
My old Miele had 700c wheels so all I had to do was pick up a 9 sp rear on ebay. The rest was qiute strait forward. It was just a matter of taking the old stuff off and putting the new on. I replaced the down tubeshifters and brakes with STI. You can use your old cranks but the front and rear ders will have to be replaced because the Suntour stuff isn’t compatible. The 9 sp rear wheel fit in with very little difficulty.
If you have 27" wheels instead of 700c I’m not sure if the brakes will work. Somebody else might know.
A good place to ask for more info might be on the newsgroup rec.bicycles.tech
“we live in a flat but rough area (kingston)”
Would this be Kingston, Ontario? I don’t live all that far from there if you need help. If you’ve got any questions just send me a personal email.
What is on the two bikes now? You can still use 6/7 sp Shimano front der but the rear will have to be replaced. You’ll need a 9 sp rear wheel. You’ll have to replace the 7 sp bar end shifters with 9 sp ones. You can keep the same cranks and biopace rings. It’s not that big of a job.
I did up the Miele with a 105 triple but also went a little nuts buying a carbon fork, titanium seat post and some some other upgrades. It was then just an absolutely beautiful bike with the modern components but classical lugged steel frame. It was as smooth as butter. It was my original tri bike but the frame was a bit big for me. I gave it to my 15 yr old son and it fit him perfectly(he’s four inches taller than me at 6"2") in the hope that he’d get into cycling. No such luck, it’s all about basketball, volleyball, snowboarding and soccer. He rode the bike twice and told me that he just wasn’t into cycling. I then sold it on ebay. Broke my heart to sell it.
My bad…way off…its 12.5 not 13.5. I forgot to subtract the inch. I measure from the inch mark to be sure I have it right…then I forgot to do the subtraction…see my screen name…I’m getting old and forgetful! : )
Hey Jim, If I remember right the latest Nashbar catalog had some Shimano long reach brake calipers. Many many years ago I changed an old frame from 27" to 700c and my local shop had some drop bolts for the brakes to bring them down. Might be still available.
Neil
Yes it is the Ontario pot-hole capital, I guess we still need to be the capital of something. I would like to retain the Biopace chainrings but am unsure of the fit of the narrow chains. (e-bay has some narrow biopace chain rings) Should I replace the rings any way to match the new chain. What is a good (we can only afford one set of wheels) wheel combination that would work well for training and racing. We are weekend warriors, although it was fun last year at the k-town tri passing more than one carbon bike going up hill (I do not swin well… yet) so some practical guidence (you are familiar with the quality of components we are on now) would be appreciated. I think that even 105 would be a quantim leap in quality for us and likely cost effective.
Thanks for the help. Rick
Having Dura-Ace or Ultegra won’t make you any faster than 105, it works just as well as anything else. The cheapest place to purchase it is on ebay.
A good cheap rear wheel set up would be any 32 spoke box rim with a sixty dollar CH Aero cover for the races. Get a good used ebay aero wheel such as a Campy Shamal or Hed Jet 60 for about a hundred dollars. They are strong enough for training and racing.
I’m not sure what you mean about narrower chains. I was under the impression that they are the same, but I could be wrong. Just phone up one of the local bike shops and ask. I’ve always found the guys at TI Cycle in Gananoque to be very helpful and friendly, although expensive. Also Cyclepath on Princess St will answer your questions. There is also a very good independent bike mechanic on Bath Rd. who works out of his garage in the warm weather. He puts a sign out front of the house but I don’t know his house number.
Paul, 12.5 makes more sense. I do the same thing when using a rule.
BTW I think that means my present calipers will work for 700 wheels.
