I’ve been tasked with finding cameras that my engineering group can use during walk downs and inspections at our power plant. My budget for (2) cameras and memory cards is $400. I’d like to get a decent MP count (at least ~8Mp) and the larger the rear screen the better. These will be used frequently in dark environments, so a solid flash system is key. Also, the smaller the better - pocket size is perfect. We’ve currently got a Sony Mavica that records to a floppy disk and the camera weighs a couple of pounds.
Optical zoom is not required. Some of the time we will be wearing multiple pairs of gloves, so super small buttons may be a hindrance.
We’ll probably be going with a “local” big box like Best Buy instead of B&H.
I’m fairly knowledgeable with cameras and own a DSLR and a couple of point and shoot’s, but I’d like to see what the LR collective comes up with from personal experience.
thanks,
drew
Kodak M1033…took it to the Giro and put a 4Gig card in…works like a charm and many shooting modes…10 megpixel - around $125 I believe. Pictures were great.
I found that one online a few minutes ago, and it looks perfect. Any downsides to it? Can you imagine using it while wearing winter gloves?
thanks,
drew
Winter gloves may be an issue…since the toggle button ( like a button mouse on a laptop) is small as are most of the buttons since its a compact camera
Only downside is it freezes every once in a while…but a simple reseat of the battery cures that.
Great camera overall though
if you have a budget for 400.00, then spend it!
Kodac Easy Share is easy to use and high quality.
Cannon’s Powershot line is great for point and shoot, and the G10 allows you to add on a flash if you need more than the one in the camera. it’s 500.00 though, but you might be able to find a deal online. very easy to use, i’m impressed with mine (although, now i lust for a Nikon d90…oy)
Canon G10
Has the best reviews of any P&S and more of my pro’s friends carry it as their pocket camera than any other.
Bottom line, it rocks!
http://www.elitecamcorders.com/product_p/cang10.htm
lookie here, lookie here! the canon at a steal…damn! and they have a killer deal on my Nikon too. ACK!!!
$400…kind of. I’ve got to get 2 cameras, 2 memory cards and I’m thinking a spare battery would be a good idea as well… Based on that, the camera has to be closer to the $150 range - but I do like your suggestions.
d
Winter gloves may have been a simplification of what we will be up against. In some areas, we have to wear form fitting cotton liner gloves covered with thin rubber gloves - some fairly unique conditions. I like the look of the cannon because the on/off button is on the top, the shutter release is on the top and is of standard size, and the mode changes can be done with a wheel, not a menu button.
d
Check into the Olympus cameras. Not sure of the current model number but they have one for $160 at best buy that is shock and waterproof. With the environment you are looking at and the layering with gloves and stuff the shockproof might be the way to go. They take pretty good pictures under water as well.
ok, this might not be a popular idea, but i think kodack makes alot of camera for the dollar.
FWIW, the canon battery seems to last forever, plus you can plug it in and recharge it. i have shot about 600+ photos on one battery charge!!! then it recharged in about an hour, it’s amazing!
the memory cards don’t cost that much.
Thanks for the link - all of those are out of my price range for a pair, memory cards, spare batteries, etc.
I ended up getting a pair of the Kodak EasyShare M1063, and they should arrive on Monday.
Thanks to everyone for all of your help!
d
