Navy Seal swim technique, video
It’s essentially the sidestroke, except that when you learn sidestroke at the Y, you keep your head out of the water and don’t take ytour top arm all the way forward. When the SEALs are in dive gear, they would usually have fins on and don’t do the scissor kick, but a continuous fin kick. It is pretty fast with fins, and much easier over long distances than freestyle (at least for me) because you are concentrating on the pull without having to engage the back and shoulder muscles you need to bring your elbow and arm up in a freestyle stroke.
More than half the field swims under 1:16 and many much faster, so I doubt they would be trying that stroke. For the others, there are plenty already doing breast stroke, which raises hell with most swimmers. I would imagine there aren’t many who are desperate enough to try a different stroke. For some slower swimmers, it may just be the answer.
Not a SEAL and never have been, but I taught myself that stroke 4 years ago and finished my first two seasons of triathlon only swimming that stroke (didn’t know how to swim freestyle laps). I wasn’t the guy you saw at the pool, but I got very close to 2:00/100m.
For a non-swimmer like me, it was the only way I could swim more than 15 minutes without being completely out of breath. I got up to 2-hours of non-stop swimming before I decided I had enough and needed to learn freestyle. It’s also my backup stroke in one week at IM-Moo if I get clocked and lose my goggles, sans putting my head in the water.
I was in SEAL Team 20 years ago. Don’t know what it’s like now but the official BUD/s (training) swim was side stroke with dive fins. We only did one open water side stroke wihout fins swim in the first few weeks of training. After that, we used fins. Once you are in SEAL Team, you can use whatever stroke you want for the conditioning swims. The good swimmers swam freestyle. The lazy slobs rolled over on their back and kicked. Side stroke is used in training because the only time you surface swim is when you are doing a beach recon (the old UDT mission). 99% of the swimming I did was underwater compas swims with a drager. We never had to swim like the guy in that video for any operation.
if i see a guy swimming like that towards me, i’m going to get the hell out of there!
especially if it’s NOT in a pool
lol…
I swim with a former SEAL and he said they did mostly sidestroke. Dude can go over 50 yards underwater no prob.
Scott was a PMC (Private Military Contractor) working for a firm based on the east coast when his security detail’s convoy was ambushed in Fallujah. His vehicles were not up-armored and his team did not have adequate maps at the time they became misoriented and stumbled into a very bad side of town near the west end of the infamous bridge in Fallujah.
Like Neil Roberts (killed in battle of Takur Ghar (sp)) and the other SEALs who have died in the war on terror he will be remembered for his courage and service to country.
Anyone tried this in the pool? What’s the idea behind the rotation onto your stomach during extention? Seems like a violation of TI principles.
Trying to keep as much of your body under the surface as possible to avoid additional ripples, and exposed stuff to get noticed and shot off.
Hmmm. I’m not saying you’re wrong, but I can do that while staying on my side- and you wouldn’t be able to rotate that way swimming the stroke with fins anyway.
Let me ask this way- would it be faster or slower to swim this stroke rotating as on the video, or maintaining your position on your side throughout the stroke?
“but I can do that while staying on my side”
You would have to dive further underwater to get your shoulder under. Then you’re not using energy to go forward, but down and forward.
"Let me ask this way- would it be faster or slower to swim this stroke rotating as on the video, or maintaining your position on your side throughout the stroke? "
Beats me. But speed isn’t the only consideration for this stroke. It’s not like a triathlon.
“you wouldn’t be able to rotate that way swimming the stroke with fins anyway.”
With fins, you don’t do a scissor kick, and you certainly can still rotate forward with fins. I don’t generally rotate as much as this guys demonstrates, but I don’t stay on my side either.
I understand.
I disagree with you about the fins- you can’t stay on the surface and get on your stomach and kick with fins without breaking the surface. But I take your point about having to be deeper in the water if you’re on your side.
Thanks.
“I disagree with you about the fins- you can’t stay on the surface and get on your stomach and kick with fins without breaking the surface.”
Well, you won’t roll entirely onto your stomach, but your upper body does rol while your legs stay more sideways, It helps to get the strech and glide required. You are right, that you couldn’t completely get on your stomach without your fins flopping out of the water.
Starting at about 3:57 on this video:
http://www.youtube.com/watch?v=3DeSyl1CGIQ
you can see about what it looks like on the surface. Very minimal action above water.
That’s the Trudgeon Crawl stroke! If my swimming history serves me correctly, it is one of the older strokes and is the ancestor of the modern freestyle. I think I had to learn that at the Y to get my Minnow certificate back in the 60’s.
This stroke has some advantages if you are swimming in clothes, and/or laden down with gear that will be causing drag and probably making it hard to stay at the surface.
Proper and efficient freestyle depends on a fairly constant state of motion and remaining basically level at the surface. The scissors kick in the Trudgeon stroke gives you some power so it is good if need to re establish your momentum between each stroke and/or get back to the surface. Because at least one arm is recovering out of the water and you are getting a full freestyle pull, this stroke should be faster than breaststroke and its more efficient.
Ditto I was about to say that (trudgeon) I learned that in the boy scouts in the early 60’s along with elementary back stroke(frog kick)
and indian crawl…
Cool brings back memories of swimming in a lake without getting beat up by 2000 other swimmers… those were fun days…
Finally glad somweone has violated T1 principles, as some of them need violating to swim fast.
lol!
I agree, but not this one. I think TI’s overemphasis on the glide and the lack of emphasis on the pull are principles that could be violated, but as far as I know, the TI concept about body position (in respect to being on your side as much as possible) is sound.
fast swimmer dont swim on their sides… hackett, thrope, philps, pipes-neilsen.
www.goswim.tv
karlyn as a great freestyle dvd. only the fast swimmers have dvd’s made.
www.aquaticedge.org
