has anyone used these ?
I finally wore out the only pair of bike shoes I’ve ever owned (1987). As a cheap bastard I’m looking at the nashbar or performance (forte) tri shoes.
Does the extra $100 for say the Shimano tri shoe buy anything significant ?
I bought the nashbar tri shoes with “fake” look pedals combo for around $80.
They are comfortable and I like them, but then I don’t have a lot of things to compare them to. I used them in IMFL and I thought my transitions and bike were pretty decent.
The only complaint is that the way I pedal the velcro strap hits the chainring and loosens. The strap got all oily/gunky until I cut about 1 1/2" off of it. Of course I tell weight geeks that I cut the strap to shave 20 grams off the shoe weight.
Stop ruining it for us who just bought new TriVents… ![]()
I used a pair of Specialized MTB shoes for two seasons, including IMLP, and was very comfortable…
I have the Nashbar shoes and have the same complaint. Can’t figure out why they made the strap to the inside so it hits the chainring. Mine has finally gotten so that it doesn’t loosen and is fine. Other than that they are fine and are cheap so that helps. I just can’t make myself pay $200-300 for cycling shoes.
“Can’t figure out why they made the strap to the inside so it hits the chainring”
Maybe you guys have em on the wrong feet?
I just bought the performance in house brand “forte” tri shoe. Seems to work just fine. I can’t tell any difference between them and other brands I’ve had. But I’m not that fast either so the difference is nil if any.
The strap closes inward too though.
This guy must have dozens of these shoes as they are always for sale on EBay:
The key to these Carnac’s is the carbon fiber sole - the sole should last longer.
I have been using my road shoes but I am going to switch to something like this when the season rolls around.
The strap closes inward so that, when open during transition, the strap doesn’t get caught in the chain ring.
I’ve had several pairs of road shoes over the years, but I’m glad I switched to triathlon-specific shoes for two reasons:
Betting venting/draining. With sweaty feet in general, I need all the help I can get, even if I’m not fresh out of the water in a triathlon. Better seam layout, so I can go sockless.
I actually find my tri shoes (Shimano TR-01), sockless, to be the most comfortable shoes I’ve ever worn. I’m glad I forked over the extra $ to go with a triathlon-specific shoe.
(While I’m on the subject of $ well-spent, allow me to suggest buying some 3rd party replacement insoles. I couldn’t believe how much of a difference my replacement insoles made in the overall comfort of my shoes!)
I use Sidi Genius 4 as a gasp tri shoe. The lower two buckles are never opened, ever. The top ratchet is closed but loose. I slip my foot in, ride, ratchet it once or twice.
I use Sidi Dominator 5 double gasp as a tri shoe. It’s the same as the road shoe, but with MTB cleats on the sole. While I sprint through transitions, I pass a ton of people slipping around on their silly little road shoes, like their wearing ice skates. It also makes it easy to do the flying mounts and dismounts, cyclocross style.
ya know, that makes a - lot - of sense… hm.
I have the “forte” brand tri shoes from performance and they are working great for me. At first, the straps were too long and kept hitting the chain ring. I solved that by using a good old pair of scissors and chopping a good 3 inches off. Now the strapes fit perfectly. The shoes vent well and are much easier to get in/out of than regular cycling shoes (which I used prior to getting the tri shoes) while still fitting very snug while i’m riding. All in all, I feel that my $60 or so was really well spent, esp. being that I am a poor college student.
I used to do this, too. But carbon soled tri shoes with a large cleat are more comfortable with MUCH better power transfer.
Interesting. I race every distance, including IM in these shoes. I also use Eggbeater pedals, and have no complaints whatsoever about comfort or performance or hotspots. Sidi shoes are SO comfortable to begin with, and the sole SO stiff, I don’t see how this can get any better, but I suppose comfort is all subjective. For what it’s worth, I’ve raced in Specialized and Shimano shoes as well, and the Sidi’s win hands down for me.
I believe the belief that a larger cleat or larger pedal increases power transfer is a falacy. The general belief out there is that you sacrifice power transfer with small cleats, but that is really up for debate, expecially when you talk to someone who has crunched the numbers.
I got the Forte tri shoes last year to replace some old Performance road shoes. Works just fine for me. I’ve had no troubles with the straps either.
I’m guessing the more expensive shoes are made of better materials and may offer slightly better performance. It may be doubtful that anyone but the FOP or elites really benefit from the performance gain.
I like the tri shoe because even though I was going sockless before, it’s more comfortable. I also started doing the flying mount with shoes already clipped in last year and the tri shoes worked much better. The Forte has a loop on the tongue and on the rear making it easy to slip them on. The single strap is easy to fasten.
Guessing again, since you mention being a cheap bastard you likely aren’t riding a real expensive bike either. No sense in getting the expensive shoes.
this is the biggest misconception in biking. yes, you will get a little better power transfer with carbon shoes, but think about how your foot pushes down on the pedal…most of the carbon sole is not even loaded…as for comfort, the stiffness of a carbon shoe is far less comfortable on a long ride…i have had a variety of shoes over the years, including several of the cheapest i could find online for the trainer, and interchange them often…both the power issue and the comfort are not what people think, or what marketing depts want to make you think…
thanks, I bought the Carnacs, only $10 more than the Forte shoes…
I’ll send a product report once I get the shoes and ride them for a bit.
I’m gonna just throw this out there but… come on go support your independent local bike shop and buy your new tri shoes and pedals from them. They’ll give you advice about what to wear, the right fit and even help you install the cleats and pedals. Can you get that from nashbar?
stepping off my soapbox
