I cannot identify where this annoy noise is coming from, at first I thought it was my bottom bracket but now I’m not sure. Here are the details:
Noise only appears when pedaling Noise sounds like a scratching, vibrating sound The faster I go - the faster the noise gets (again, only when pedaling) Brake pads are not rubbing
Here’s your checklist:
Be sure your rear quick release skewer is tightened and your rear wheel is in alignment with the frame (not crooked). Be sure wheel clears both brake pads. Verify that brake pads hit the rim (not tire) when they are closed. Be sure your front derailleur cable is not scrapping your shoe/pedal/crankarm/chainring when the chain is on the large (or small…) chainring. Shift your bike to the 53/15 gear (big chainring, middle of cogset). Pedal. Is the chain scrapping the outer cage of your front derailleur? Shift to the 53/11 gear (big ring, smallest cog). Is the chain scrapping the outer cage of your front derailleur? Shift to the 53/23 (big ring, big cog- the “crossover” gear). Is the chain rubbing either the inner or outer cage of the front derailleur? Shift to the 39/11 (small ring, small cog, the other “crossover” gear). Is the chain rubbing the big chainring as it comes off the small ring and heads toward the rear cogset? (Note: This is a frequent, unavoidable circumstance on some racing frames. Solution: Avoid the crossover gear). Return to middle of cogset and big chainring. Pedal the bike and carefully follow the path of the chain around the drivetrain looking for anywhere the chain may be rubbing. Call a pizza place, order two mediums, take them to your local bike shop, give the pizzas and your bike to the best mechanic and come back in two hours. The noise and the pizzas will be gone.
**Be sure your rear quick release skewer is tightened and your rear wheel is in alignment with the frame (not crooked). **
Check the front quick release, too. I’ve traced many creaks to a front skewer that was too loose or too tight. The creaking is always in synch with pedaling action, so it’s easy to mistake for a BB/crank problem. Sounds travel on the bike like a cricket in a dark room.
Have never greased my cleats before, but if greasing the cleats doesn’t work, check the screws that are holding your cleats in place. They may be loose. I’ve tightened the cleats on my shoes and eliminated the issue.
Well, I did all the suggested steps up to tribiker’s post. The noise was completely gone until 5 miles into my ride - then it came back.
I’m beginning to think the the noise is coming from the back half of my bike but who knows?? As mentioned before - the noise only appears when pedaling and the frequency picks up the faster I go and not based on my cadence.
UPDATE: This noise gets more and more mysterious. It seems that the noise does not present itself until 5-10 miles into the ride then it continues through out the ride. I put the bike away for 8 hours - jump back on. Again, no noise until I get 5-10 miles into my ride??? I totally baffled.
Sorry if I missed this - But does the noise stop if you stand on the pedals and take all you weight off the seat? My DA has a noise that is driving me nuts, I thought it was the BB but just discovered it is the seat post clamp. If I stand the noise stops. If I remove and re-torque the seat it goes away for a short time.
I had a mysterious noice like this - it ended up being a small crack in my carbon seatpost - the carbon frame amplified the noice and make it sound like it was comming from the rear triangle. Check your seatpost.
Go thru your bike and make sure every single bolt is tight. Sometime noises come from the weirdest places.
If it is a repetative noise you need to think about the noise patter and what is “cycling” on your bike to match the noise. Wheel spin, candence, body movement. Take some serious time to concentrate on the where the noise matches and that will help solve your problem much faster.
I had a noise in my front end once for the life of me I could not figure out. I even blew out the inside of my bars thinking my buddy at the shop had hidden something in my bars to mess with me. Turned out all I needed to do was tighten my stem to bar bolts.
One more thing to try: Going done a gental hill at a reasonable speed. When pedaling slower than bike speed, is the noise still there? Or do you need some pedal force to cause the noise. My noise was from the rear derailleur idler wheels, but I could only hear it when I was next to some kind of wall (to reflect the sound).
