My turn to get roasted
I’ve been tweaking my position over the last couple of days, and would appreciate any feedback. As usual, garage, paint, junk, etc… are all up for comment. Thanks.
Stuart
http://i13.tinypic.com/2iseagz.jpg
Nothing wrong with it. Nice and low.
I’m wondering about the saddle height. Is it milimeters to low, or is it just me?
Looks very good to me but I know little. I’m not as brave as you (to post pics) but would like to know how you went about fitting yourself. I just build up a dedicated tri bike and plan to get professionally FIST fitted soon. But I would like to get a ballpark fit myself in the meantime. Are there any pointers you can give me? My current setup feels fine but I’m way too upright. I really can’t lift the seat any higher so what are my options for getting my hips higher in the air?
Well, I hate to say it, but seat does look slightly to high. Also, why the upturned stem, yet it is slammed on the headtube with zero spacers? Flipping the stem too low? Otherwise, looks pretty good!
But, what the hell are you using for your front wheel riser?
Position looks great. What do you keep in the cage on the shelf?
That’s what Kurt Kinetic sells as their riser. I have one as well.
As for the OP, my amateur suggestion / nit would be that you seem to be reaching juuuuuuuuuuuuuust a tad. Perhaps getting your arm angle a little closer to 90 might help. Also, the stem issue that rroof raised is interesting, but it doesn’t really look like it’s pushing you up too much.
the cage is for my 26 lb cat. he really needs something bigger and sturdier, but i haven’t gotten around to getting him a new one.
Hey. I really suck at this, but, then again, you posted for advice on ST. So, I’d say your upper body looks a little stretched out. Perhaps you can get the shoulders more over the elbows.
BTW, I’m calling the cops about those stolen Milk Crates in front of you ;).
Good luck,
Brian
Darn… You beat me to it. Good advice though :).
-Brian
According to conventional wisdom here, you are a little too stretched out. Only you will know this for sure though. Doesn’t look like you can go too much smaller on the stem. Can you get your seat more forward? Also, your seat does look a little too high. If you move your seat forward, it might fix that also. Overall, pretty good though, as long as you are comfortable for long distances.
I like the Festina era Specialized in the background but it needs white bar tape and black tires ; )
Did you steal those milk crates? As a milkman, we lose millions a year. Milk/gallon could be half price!
As for your Q. Shorter stem, reverse it, aerobar pads closer to the body, giving you a better 90 degree angle of the arm (I would imagine that the less outstretched arms would enable you to flip that stem, with minimal change in body position). Seat post height - I believe a personal preference, unlike the arms which may lead to fatigue.
How tall are you?
No expert, but from what I have read, I have my seat a little lower so my knees are a little more bent. I also have a 90% at the elbow and shoulder, which does that imply the top tube is a little long?
Dave
You have a nice long torso. You’re low, but you could get a little slightly more forward by sitting with your sits bones (ischial tuberosities) more forward on the nose of your saddle. If you like your postion and it’s comfortable though, then stick with it.
I’d say a little stretched out.
Shoes need pollish.
Is that a Hed ten spoke back there on the left?
Good Luck!
Seat a little lower and a little forward…you look a tad too high and too stretched out but not by a lot…your upper arms should be near vertical
And you know what they say about a man with a nice long torso
Quatsch. This position looks just fine. Leave it as it is.
-jens
Do you really need car “stops” in the garage to keep from hitting your shelves? : )
Now all you need is a tennis ball hanging from the ceiling that hits the windshield when you stop in the right place : )
Thanks to all for the comments. It’s a big help, and generally confirms my feeling that I am still a bit stretched out up front.
Peleton - In response to your question about how did I fit myself, I just printed out Slowman’s fit article (excellent, in my opinion) from this website, and went into the garage. I put blue painter’s tape on the various bony protrusions referenced in Dan’s article, put the camera on a tripod, set the timer and had at it. I took a bunch of pictures and brought them all into AutoCAD where I could draw lines between the blue tape dots (photoshopped out of the pic I posted so as to avoid any smurf-chickpox comments) to check angles. I did that for all the pictures so that I could average the numbers, figuring that I didn’t sit on the bike in exactly the same way each time. Do all that, learn what you learn, adjust what looks like it needs adjusting, and repeat.
The biggest thing I’ve struggled with is exactly where to draw the torso line for the hip angle. Because of where the protrusion is on the collarbone, I can’t see my tape dot in the pictures and I think I was drawing that line to ‘high’ when doing my analysis. All the comments about being a little too stretched make sense if the hip angle is a bit more closed then I was calculating it, resulting in an arm angle that is a bit more open. A honest look at the pics reinforces that conclusion. Anyway, now it’s down to the garage, shove the seat forward a bit and try again.
I don’t. A physical barrier to forward movement has proven to be a significant benefit to my wife however…
