This is a 2008 TTX in a modified Project one scheme. The derailleurs and bar ends will be switched out for the SRAM TT stuff one of these days. THe aerobars will be trimmed after the fitting is completed. The race wheels are the Hed3 clinchers and the training wheels are the Bontrager Race XX lite Aeros. Paint scheme will be around this year only. Next year colors will be changed out. What do you think?
its nice bike
only from aerodynamics i would close the hole on crank cost you lots of second now
and big pedal surface why no a flater pedal? its ore aerodymamic?
also wold try to find closed chainring for aerodynamics and would move you cat eye to place behind you stem you just in front of it
also would mve the sensor behind the vork not in front of it
would close the under side of the saddle since all those thing cost lot of time
also would level the handle bar about 1 or 2 degrees
as it not its catch lot of air
The pads are quite squishy and comfortable. Not bad at all longest being a four hour ride.
The frame is a size L.
The waterbotle covering is actually a holder for the CO2, levers, tube and crack pipe.
The bottle cages are the Carbon Race not the XXX race lite cages. Havent launched a bottle yet.
On the training tires they are blue Bontrager Race.The sensor will be moved this week, I am waiting to move the Cat Eye after the fitting is complete.
Actually I am going to get the Project one in Red/Black/Hight Polish Chrome at the end of this race season. That will tie the components all together then. When we put it together I didn’t want to wait for the parts to get “Project one’d”.
Nice bike - the drivetrain will last a lot longer if you do not cross-gear as you have in this picture (sorry - it’s slowtwitch and I couldn’t find anything else wrong in the pic)!
sadly no pics
but piece of carbon or glassfiber will do the trick
would not cost much too even make it a store room for tryes ( for a flat trye and co 2)
better aerodynamic and you have all this out of the way
hence if you it good even can make a water storage place for it
when i did double dutch tri i had something like this
again sadly no photo of it ( it so long ago)
