My legs quit before my engine does. Is this training block built for the wrong limiter?
garbage in garbage out that sums up the garmin vo2 max guestimator .
5 k is solid .
there is other profiling you could do. at the same time if you did a lab test with somebody that will help you to understand what you need to focus on would not be a bad idea from what I read so far ( ie you seem to be data driven but could do with some guidance). meaning the lab test is not so important to talk to somebody that understands and is willing to explain you your physiology and points you to some literature would be great )
my 2 cents based on very little info.
On the strength piece, since you said lifting on easy days wrecked your next hard session… have a look at isometrics. Short maximal holds instead of reps, so there’s no lowering phase, which is the part that usually leaves you sore.
This is the protocol we use (both exercises are watchable on YouTube):
3-min rest between sets - 3s maximal holds per rep
Week 1-2: IMTP 3x3 | Iso plantar flexion 3x3
W3-4: IMTP 3x4 | Iso plantar flexion 3x4
W5: IMTP 3x5 | Iso plantar flexion 3x5
W6: IMTP 2x5 | Iso plantar flexion 2x5
Lum, D., Barbosa, T. M., Aziz, A. R., & Balasekaran, G. (2023). Effects of Isometric Strength and Plyometric Training on Running Performance: A Randomized Controlled Study. Research Quarterly for Exercise and Sport, 94(1), 263-271. (Study was on runners, but I have found it the flexion helps will the bottom end flick on the bike.)
We do the plantar flexion with a heavy band doubled up. The band wants to come off your toes and smack you in the face, but it works. The mid thigh one you feel the whole chain light up.
Just a couple of low fatigue ways to attack the problem.
