My left heel hurts, help please
At present I have not been to the foot doc. About a month ago I started noticing a bit of tenderness in my left heel, on the bottom wrapping around to the inside and up, staying within the heal area. No trouble with the right heel. It was way beyond time for new running shoes, so I got a new pair, same model, that I’ve been wearing forever. Since then I’ve gone back and forth, finding zero differences in the shoes, with which I wear custom orthotics, replaced every few years.
Pain is now constant whenever there is pressure on the heel, almost an even amount of discomfort over the entire heel area, but more so on that original area during running.
I ran the other day with my old major cushioning/stability shoe - Brooks Beast, and the pain during running was greatly decreased, yet still present thereafter. I have also experimented running without my orthotics - not good on my knees. Pain upon taking those first few steps in the morning is substantial, while mostly annoying at other times.
I have decreased my running, even taken nearly a week off, yet it is still there.
Thinking of what has changed if anything - I’ve taken to using fins for kick sets to strengthen up these weak hip flexors of mine, occasionally I wonder if the fins are contributing.
Lots of tennis ball rolling around under the foot (aaahhhh) and focusing the hot tub jets on the foot every day is extremely comforting, too.
Should I be icing this after running? Not running at all? Ibuprofen/NSAIDS I’m not really thrilled about. Did I just bruise this thing I wonder? I don’t recall any trauma that would have done it.
I don’t really expect answers, but its probably time to go to see Dr. Senatore again… Thanks for any comments/advice/etc… (well not ANY comments necessarily)
The last time I had tenderness over a bone, it turned into a stress fracture. (Not trying to scare you, well maybe, just be careful!) Do you have any point tenderness (ie, if you touched one specific spot you’d be in a lot of pain) or just general tenderness?
good luck, hope it’s nothing major
tc
I can’t tell from your description where the pain is located exactly. Plantar Fasciitis can be isolated mainly to the heel. When my PF started it was more in the heel area. Right at the front of the heel with pain radiating to the middle of the heel.
Mike
Could be a number of different problems. If you’re having trouble in your heel, and it doesn’t travel throughout the rest of your foot, it is likely that you do not have plantar fascitis.
You may actually be experiencing a stress fracture or a problem with your achilles tendon at it’s insertion level. Your best bet is to see a PT as soon as possible.
I heard this can happen if you don’t spin dry your suit after swimming. Something about the new suits and chemical when under strain.
Could be an early stress fx, as tigerchik suggests, but it also sounds a lot like plantar fasciitis - especially the part about pain most intense when you wake up in the AM and take those first few steps. Stretching + icing will help; there have been a number of threads about this, and you’ll find them if you search “plantar fasciitis” on the forum. Shd probably see a podiatrist or orthopedist.
Good luck.
I’m paranoid and think everything is a sfx :frowning:
If you’re a hammer…
On the other hand, my PF has always been pretty localized. And, since it’s dominating my life (to the measureable benefit of my swimming!), I assume all heel pain is PF.
sounds a lot like plantar fasciitis to me (and I just saw 8 people today with it) :frowning:
Heel pain syndrome (as is more properly termed though) runs the gambit of things like PF, infracalcaneal bursitis, calcaneal periostitis, etc. All treated/managed about the same, but each person responds slightly differently (which is why you hear so many wive’s tales about what worked for one person in 1 day while others suffer for months on end). However, you are getting closely suspicious for a calcaneal stress fracture that really should be ruled out - a lateral wall fracture, while rare, would be devastating (like no running again forever bad).
Good luck.
It’s obvious that your seat is too high!
Seriously, I struggle with achilles problems and my heel pain is relegated to the top of the heel and it hurts like hell in the mornings. Does your pain start underneath the heel or on the bottom of the back of the heel? If it is on the bottom of the back of the heel than it could be achilles. There are some good stretches that, when religiously executed, keep me sbr’ing. Let me know.
I might have your cure…
It sounds like Plantar Facitis, however it could be more serious. Try this, get a compression wrap, like the one made by “ArchAid”. Keep the compression wrap around the arch of your foot for 3-4 days straight and only take it off when you go to bed at night.
This has worked for EVERY customer I’ve had with Plantar Facitis and myself. It will be gone in 3-4 days. If the pain persists then it may be something else.
It can’t hurt, give it a try and let me know.
Thanks,
I have been dealing with exactly the same problem and will find out this week if the MRI shows a stress fracture. Do not take this lightly. I have had several surgeries to my left foot for genetic issue and never expeirence either plantar facisitis or a stress fracture in over 35 years of running. I have been sleeping with a nightsplint with good results but still have the pain when I try to run. Try to ride/swim as much as possible until it heals and get to a foot doctor asap.
