Bars are set up wrong. Should be rotated enough to get the drops in a usable range. Bottom of drop should be a couple degrees from horizontal- then you raise the shifters on the bars to get them back in a good position so you can hold them from the top and get to them from the drops. FSA and most manufactuers suggest this for their bars. FSA suggests that the bottom of the brake lever to be 3-5cm higher that even with the bottom flat part. It works.
Running brake levers even with the bottom of the drops is not really valid unless you have big hands and big reach.
Guru can only do so much with the amount of top tube slope on the Geneo. So if you want a taller headtube you have to build up the seattube length. by the looks of the seat, i wouldn’t want to raise that. If she wanted to do an aero front end in the future then the front might look better.
Before posting wanted to double check the positioning of the ritchey carbons with their website and they are correctly installed. Here’s a link showing the install. http://www.cyclingnews.com/tech.php?id=tech/2005/reviews/ritchey_wcs_carbon_bars
I’m not a bike mechanic but all of the lines and grooves are perfectly aligned.
kelli
Lines and grooves only tell you side to side, rotation is another matter. Lines could not line up for rotation- it would not acconunt for positive or negative rise stem. Rotation would be different for each orientation.
There is room for personal preference- I just do not think you are doing all that you can to make the bars comfortable. Think about this- bottoms near flat- brings the drops toward you (but hoods away). So move bottoms toward flat, raise hoods to bring them back to as close or closer (may want to measure saddle to hoods before you do this).
I guess that it’s time I pop in.
First of all, thanks for everyone’s support with comments about the shop. It’s a lot of hard work, and my overall goal is that everyone who walks through the door has a good experience. Whether you buy something or not, you have enjoyed coming in, smiled a little, and left with a good feeling. Thanks for that!
About Gurugirl’s bike:
Gurugirl had very specific ideas when it came to her new bike. She was spending her hard earned cash and she wanted it to be very versatile. Guru was extremely helpful when designing the frame with the idea in mind that this entire front and was going to change for her races. We’ll post pics when the swap occurs, and judging on the bars she wants, there will be plenty of drool on your screens.
Spacers, stems, bars blah blah blah. Noone has seen her or seen her height, arm length, inseem riding position, etc. To have her fit correctly I would have put another spacer in if her angles of measurement AND comfort weren’t in line. Just because a bike is “custom” doesn’t mean that there will be ZERO spacers. The bike is custom so that she can manipulate it in any way she would like. The head tube length and seat tube angle are built so that she can go either way with the fit. She not riding this bike in the Pro Peloton so her drop doesn’t need to be 15cm. She also isn’t out of the saddle sprinting on the drops, so it really doesn’t matter where they are positioned. She is comfy where they sit now and we’ll change it as needed. The stem IS installed correctly as the ritchey stems can be reversed for more or less drop or rise as needed for the rider. The million dollar question is…Is she comfortable on her new steed? We can let her answer that…
Other than not setting her cranks straight, trimming the vines off of the fence, cutting off the front wheel, and not sweeping the sidewalk, I personally think it’s a great picture! Sorry Kelli, I had to throw in some slowtwicth staples.
Hmmmm…I see your point now and based on the fact I almost did a face plant on the stem when I went to get in the drops and missed on my first day of riding it it is something I might change. Right now I’m just so comfy and, for the first time since moving to socal, I’m really enjoying riding hills so I’m not ready to change things up yet. I’ll definitely keep this in mind as I ride over the next few weeks and I definitely appreciate the input.
kelli
orange bar tape, or maybe better yet silver carbon look bartape. You need some orange and silver zipp wheel decals too:)
Jeff,
Thanks for chiming in and expressing what I was unable to communicate. That is why I wet to you for this bike…I knew you could translate my crazy idea to guru and, now to slowtwitch.
Those vines and leaves are all from the neighbors and I’m waiting for them to hop the fence and pick up after themselves! ![]()
Thanks for everything,
kelli
Ahhh, I like the way you think…need more orange!!!
kelli
ha, and i was trying to sell my services:) if you give me some measurements on those zipp decals I can set you up with a orange set of decals for $20! if not definitely orange or silver bar tape, nice bike though, love the Gurus
The three manufacturers that make orange bar tape would not “match” the same. It would look a little goofy actually, but I’m happy to throw it on if you’d like. I have orange tires here as well!
Well you’ve started a battle!
Before i moved up north, EDGE / Hank was my shop and nothing but great experiences with them…hope they are still doing well.
btw, love your bike…that orange / grey is very nice!
Hey Kelli…awesome Guru. I have the crono and love mine.
Very nice bike!!
PS: I think Jeff and the staff at Ladera Cyclery are great.
Very nice. Why did you decide to go with SRAM?
Spent a lot of time researching what components to get and I was very intrigued by SRAM. Seemed like the main drawback to them was getting used to the double tap shifting and, since I was going to have to learn a new way of shifting anyway, I thought I’d give them a try. Also, there were a few things that bothered me with the dura ace I have on my old tri bike, price took record out of the mix and admittedly I liked the look of force. Not exactly a scientific method but more a process of elimination based on weight, looks, and price. So far I’m happy with my decision.
kelli
if not use a few sic day ![]()
Thom/dirt/cheyou
sic (sic) for sick?
Brad
