My first ride on the CT -- help me digest results
Got the CT last week. Had my usual Sunday off last weekend. Then, 2 days skiing, 1 day travelling and interviewing, 1.5 days of expelling a cold from the body this week has brought me to today. I figured that I’d give “The Monthly Test” (http://home.trainingpeaks.com/articles/cycling/training-explained.aspx ) @ the 20min duration a go.
The wheel was clean. Warmed up the wheel and CT for about 25mins. Calibration result was 3.8-something. Loaded a flat 40K course (courtesy of STer rmur) and began. Having already warmed up I started the 3 x 100rpm sessions, and proceeded to do the 20min test. I concluded as “The Monthly Test” directs.
So, now I have these:
http://i43.tinypic.com/5ff4lv.jpg
http://i42.tinypic.com/11wfq88.jpg
So, having read several previous posts for determining FTP and knowing the general rule of 0.95*20min, I still have some questions.
If my FTP is going to be 0.95*20min, then what is the 20min value that I use? Do I use the maximum wattage from that 20min period? Do I use the mean from my min/max wattage during the 20min test?
Then, what am I supposed to understand from the power numbers for the 3 x 1min all-out efforts and the 3 x 30second super sprint efforts?
Is there some kind of combinatorial algorithm between all these sets that gives me a better estimation for FTP?
Yes, I know, buy the book, purchase WKO+ , read everything under the sun for training with power…Just give me some guidance here since this was my first session on the CT.
Thanks.
I think this would represent conventional wisdom: you want to use the normalized power from your 20-minute segment. Since you are riding steady this will be quiite close to the average power. Most people use WKO+ or its predecessor to set a range for the interval and spit out the numbers. Since you don’t have it, you can take an eyeball average (or a few watts higher since you had more power toward the end of the interval) and use that for your 20-minute power. In the Allen/Coggan book they detail a test where during the warm-up you do 5 minutes all-out before moving on to the 20-minute test. This 20-minute result times 0.95 is a proxy for FTP. (The five-minute segment adds a fatigue element that depresses your 20-minute value from where it would be if you did it fresh. In your case, the test you did gives you a fresh 20-minute power and this number times 0.95 would over-predict your FTP a little.) “Oh, crapola,” says you. “I only have this fresh 20-minute power number.” Well, you could do another shorter test (5 minutes is typical) and use one of the on-line spreadsheets to calculate your critical power and get an estimate of your FTP. Here is one site with an explanation and downloadable spreadsheet:
http://jorgepbmcoaching.blogspot.com/2008/11/how-to-calculate-your-critical-power.html
If this whole post is totally incomprehensible, it’s time to do some reading… :slight_smile:
Thanks for the reply. No, not incomprehensible.
I don’t have the book. I was following the protocol from the website.
The Monthly Test: 20minute warm-up, which is just riding along at a moderate pace, about 65% of your max HR. Then do (3) fast pedaling efforts for 100rpm for one minute each with one minute between each. Then 3 minutes easy… Then Go for it - (1) 5minute all out. Punch it and hold it! Make sure that you start at a high pace, but not soo high that you die at the end. You should have a little in reserve to kick it to the finish line in the last minute.
You need to do a separate test on another day for a solid 20-minute effort as hard as you can go. Same warm-up as above, including the fast pedaling intervals, but now just do the 20 minute Time Trial.
I certainly didn’t go all out for 5min during my warmup, but I think for a period of time I was probably above 65%. I’m not so concerned, because it seems that there are as many different approaches for estimating FTP as there are coaches. I’m more focused on figuring out a method that I’ll continue to use time after time.
I understand NP, but obviously I don’t have WKO+. I probably should just plunk down for it and be done. Anyway, I did average some 30-odd points just by moving the time bar throughout the 20mins to get a number.
I don’t suppose there are any free analysis programs, huh?
Thanks for the CP assessment guidance. Shouldn’t the 5min interval be done in the same session as the 20min interval? Or, if I do some warmup and spinning like yesterday and then hammer for 5mins, then that’s going to be fine?
My only other question refers back to the rest of “The Monthly Test,” and I suppose that WKO+ again comes into play here. For now, they would only serve as a benchmarkers from month to month, and WKO+ would somehow work them into a finer FTP estimate, yeah?
Cheers.
3.8 is very high for a calibration test. Normally id keep it around two.
Also your HR is very low for an all out effort, which would make me question if thats your true 20min wattage.
Well, I can only say that I had seen the numerous replies in other threads discussing the need to calibrate well, which is why I warmed up for 25mins. When I grabbed the flywheel and tried to pull the wheel over it, it wasn’t budgin’. It was pressed onto the wheel pretty well.
In regards to HR, I don’t know what to say. I do know that it felt like a good effort. I paced it knowing that I was going drop down another gear with 2-3mins left and push it. I don’t know if I could really say how much longer I would have been able to sustain that effort towards the end of the 20mins.
tough to tell from one ride. the best way to test your FTP is with an hour long, all out, effort. barring that… the .95*20 will give you a decent SWAG at it and should increase as you get more fit. as you get more used to the CT you should have a better idea of how hard you can go. Unfortunately you need to recalibrate when you get outside since there isn’t a 1:1 ratio between indoor watts and outdoor watts.
Plus - your cadence is too low.
-you’ll plunk sooner or later… :slight_smile:
I don’t suppose there are any free analysis programs, huh? -not that I know of. If you have a csv file of the power data you can calculate it yourself using excel. It’s a pain in the ass and after doing it myself for a week I bought cyclingpeaks (the predecessor to WKO). I won’t take the time now to detail how to do the calculation, but if you want to pursue this angle PM me.
-you are correct in that there are many ways to estimate FTP. One could broadly categorize the quickie ones into 1) single tests that involve hard efforts shorter than just doing a 60-minute trial with some correction factor to get to FTP, and 2) methods that require all-out efforts at shorter intervals than 60 minutes, and you extrapolate a line to get an approximation of 60-minute power. The one in the Allen/Coggan book is an example of (1) and the critical power methodology is an example of (2). For way (2), you need to do each one fresh to get real all-out efforts. (Although people sometimes do 1’ and 5’ tests in the same workout. The idea is that they are truly all-out efforts.)
My only other question refers back to the rest of “The Monthly Test,” and I suppose that WKO+ again comes into play here. For now, they would only serve as a benchmarkers from month to month, and WKO+ would somehow work them into a finer FTP estimate, yeah? -I’m not sure exactly how to answer this, probably because I was too lazy to carefully reread “The Monthly Test”. In order to hide my laziness behind a facade of scholarly detachment, let me ask you some questions. :slight_smile: Why do you want to know your FTP? Will you use it to build workouts? To build race strategies? To keep track of how much progress you are making? If it’s the last one, then any repeatable test will serve. Are you a bike racer? If so you’ll care about tracking capabilities for shorter efforts like 1’ and 5’. (Or maybe if you’re an ITU guy and have to cover a break.) If you’re solely a triathlete, the shorter benchmarks won’t matter as much. I guess my point is agonizing over true FTP only matters if you’ll use it for something. Just some things to think about… -and with regard to heart rate, even though I admire his contributions to the 200W/<30min20K thread, I’m going to disagree with Grant and say that heart rate is individual enough that only you can know if you went all-out in your 20-minute test. edited to fix formatting – we’ll see if it worked… It didn’t work…I give up.
I think this is THE book everyone refers to, yes?
http://www.amazon.com/Training-Racing-Power-Meter-Hunter/dp/1931382794
I’m using FTP/power to base my workouts around. When it comes time, hopefully, I will have a race strategy as well.
Cheers.
