First off, I am relieved that you were not seriously injured. Thank goodness. Also, I was laid up some period of time by an interaction with a bus, so I always feel my stomach churn when I read these posts.
However, this would be an interesting poll for most triathletes: Who was at fault here?
I think you were, and I think that the problem is not understanding the vehicle code and why it was set up as it was.
As a bicyclist, you are to operate like a motor vehicle in most ways (see John Forrester’s “Effective Cycling”). It is the rule that bicyclist stay as far possible to the right on road, so that they may be passed safely by faster motor vehicles on the left. In your post, it is clear that some how you assume that bicyclists have a special lane to the edge of the road where you are entitle to then PASS on the RIGHT. This is not true unless it is marked as such. It has been years since I biked this strip (I normally bike Santiago Canyon), but I don’t think it is marked. (Right?)
I think that if we went to a court of law, I could see a very strong angle where you were proceeding in an unsafe manner, with a disregard for common safety. I don’t think that we could find a clear statute in the Ca Vehicle Code where she was at more fault than you.
What was the woman’s fault?
- Not signaling her intentions far enough in advance. However, this is pretty common, as she just saw the parking space, and while she should have signaled at the same time as she turned, I don’t think that this would give you any more warning.
What was your fault?
- Not giving adequate following distance.
- Passing on the right.
The majority of burden for passing safely is ALWAYS on the passing vehicle, NOT on the person being passed. In other words, you would need to show that she had a flagrant disregard for safety in her driving before she was at fault.
You assumed that you could do two related things:
a. Pass her.
b. Pass her on the right.
You then assumed that she’d know that you were passing her on the right. Most places in Europe it is illegal to pass on the right in any vehicle because they believe it is unsafe. If I used YOUR description, I would probably come up to you this instance and say:
a. You should be passing on the left.
b. This campground conduit is not your personal workout space (I also have biked this section) and therefore you must operate like a motor vehicle.
c. You should have continued to follow her at a safe distance and sacrificed a bit of hammering for safety sake. When she was “driving slow” this should have been a tip that something was up. If you are driving a car, and the person in front of you is driving slow, generally you slow down and simply follow this person slowly until you have a clear and wide open space to safely pass.
I may have misread your description, so I apologize in advance if I missed something. However, I think this would be worth a discussion on any front, as I believe that this something worth thinking about.
(BTW: If she had passed you, then turned in front of you, it would be a totally different situation.)
Theo
