One of my new years resolutions is to learn to play the clarinet… first thing first, I need to buy a clarinet.
Any clarinet players out there with recommendations on how to buy one. Good brands?
How do I go about this?
Andrew
Andrew
Nice HUGE picture! That’s not a clarinet either. It’s a saxophone.
Replying as a parent (from a funding perspective)
If you are taking lessons, check and see about a rental from the store where you are taking lessons.
My son learned on a Buffet, sounded great. Was able to buy the instrument at a reduced rate after the first year. Moved to a wood clarinet when his talent proved the need.
Get ready for a few squeaks. It is a heckuva lot harder to play a clarinet than it looks.
Will improve your lung capacity. So it is a good thing for an athlete.
Good luck.
my suggestion is to go for a rental for a few months to make sure it’s something you really want to do (and have aptitude towards), then start looking on craigslist for used ‘student model’ instruments (plenty available, the clarinet being probably the most commonly played band instrument), after a year or two you will likely know if you’ll stick with this long term and if you can benefit from a higher quality instrument.
Is there a huge sound quality difference between a student model vs a non-student model?
Is the student model easier to learn on or is it simply bulletproof.
I tend to take care of my things and they last a long time so that is teh only thing that makes me want an upgraded vs a student model.
Thoughts?
I played alto sax in H.S. (not very well though), that is not an alto, baratone or tenor sax. It looks like a clarinet to me (my sister and my mom both played clarinet), although all the clarinets I ever saw were black.
**Is there a huge sound quality difference between a student model vs a non-student model? **
Yes, but you will not be able to tell as a student.
It is exactly the same layout of keys. The biggest difference is in the care of the instrument. The student type is plastic (resin). The best are wooden. Wood takes maintenence. With either, make sure that the pads under the keys are relatively new. A loose pad will result in squeaking or silence or other issues that will frustrate you. The price differential can be staggering. Until you develop some skills, you would not benefit from a high priced model.
Clarinetists make better lovers. No joke, your mouth will feel like it ran a marathon for a while. Start with a really soft reed and stay there until your mouth and tongue adapt. (There is a sort of macho competition to move up to the stiffest reeds too soon.)
Stick with it, there is nothing like the sound.
"I played alto sax in H.S. (not very well though), that is not an alto, baratone or tenor sax. It looks like a clarinet to me (my sister and my mom both played clarinet), although all the clarinets I ever saw were black. "
Wow… quite an indictment of the musical education at your HS.
That’s a Soprano Sax.
Kenny plays a soprano quite frequently, as have many jazz artists, such as Wayne Shorter and Coltrane… not to mention Sidney Bechet, who is almost entirely identified with this instrument.
“With either, make sure that the pads under the keys are relatively new. A loose pad will result in squeaking or silence or other issues that will frustrate you.”
This is a very good suggestion, and I would add this; if you don’t know a fair bit about the instrument you are buying, buy from a reputable dealer.
Woodwind repairs can very quickly add up to the point that any price difference between the local instrument purveyor and the “good deal” on E-bay or Craig’s list disappears. You will go crazy trying to learn on an instrument that needs an overhaul, and a basic overhaul on a student level clarinet will typically cost between $300 and $400.
It is a soprano saxophone. There were some metal clarinets made during the 1930’s and 1940’s. Most premium clarinets are made of wood. Cheaper ones (think student models) are made of plastic.
Most student models, I’m pretty sure, are plastic. Most better models are wood. HUGE difference. Look for a Selmer or a Buffet if you are looking fora good quality clarinet. eBay probably has some good deals. You might also want to check your local music store. They could probably at least point you in the right direction. Also, check in at your local high school. THe band director though might be more than willing to be a resource. The same goes for a local community orchestra.
It is hard to imagine a harder intrument to learn (IMO). I studied music in college for the saxophone. I learned the piano, flute, cello, violin, trumpet and piano. For the life of me I could never get a decent sound out of a clarinet though.
Bernie
Tri in oc
I assume you are in OC CA, do you have a good dealer you go to?
“Wow… quite an indictment of the musical education at your HS.”
In high school I was pretty good a lot of different things (Honor roll, lettered in 2 different sports, was involved in 4-H yada yada yada). I was just ok at band and so to me that wasnt very good. We actually had a very good H.S. band (especially the marching band). We didnt have any soprano saxes and until now I have never seen one. Thanks for the clarification.
Me too, first chair
(look at the band geek here everyone!!)
Anyways, you forgot soprano sax. Kind of sorta shaped like a clarinet, but isn’t.
There is a huge difference in sound quality as you go up the scale of “professional” musical instruments. I played alto sax in high school and our band was taken pretty seriously and had a lot of money. Each first chair played on a professional model of their instrument. My personal instrument was a big POS. I basically gave up trying to play after high school because the instrument was so inferior.
**Is the student model easier to learn on or is it simply bulletproof. **
It’s easier to maintain and a “safer” investment if one decides they no longer want to pursue the playing of said instrument.
**I tend to take care of my things and they last a long time so that is teh only thing that makes me want an upgraded vs a student model. **
A studen model will also last a long time if one takes care of it.
Wow, I was way late on the soprano sax response!
Are you familiar with the circle in orange? There is a store right near there that is a big hub for music. No, for the life of me, I can not think of the name.
Someone suggested school band directors. In my experience, these guys are great resources, if a bit hardcore. (“You have to prioritize your life. You can do your school work and sports or you can progress in this band. Remember, band is your life.” No, he was not kidding in the least.)
Is this it?
Praxis Musical Instruments Inc
Address: 1531 W Collins Ave, Orange, CA 92867 Phone: (714) 532-6655
I don’t think so. Seems farther from the circle than I remember. So I called them to ask. They just had an answering machine working. Give it a try and if they don’t, the may be able to refer you.
