I recently bought a mtn bike and was wondering if I should keep anything close to my tri bike fit. I know there is a HUGE difference in geom. but curious if knee angle should be kept pretty close to aviod injury or anything else. There is a major difference is that I have 175’s on my mtb and 172.5’s on my tri. Also I would guess you would need to take cleat/pedals into play being that speedplays probably have more height than shimano spd’s.
Any help would be great!
I have dealt with IT band issues from the bike in the past as well and gracilis tightness to so trying to avoid it
I would not suggest trying to set your mtb up the same way as your tri bike, it will lead to poor handling and likely OTB if you run that much drop!
I usually run the saddle 1/2 to 1 cm lower and the bars about 1"-2" below the saddle for a more XC oriented fit. Reach to the bars would typically be approximately 3cm longer than the road bike, depending on how your tri bike is set up it would be quite a bit more. Look for a shop with some experience in mtb fit. A more “all mountain” or position would have the bars closer and higher.
I wouldnt be concerned about the change in position, many triathletes swap between tri and road bikes with different saddle positions without difficulty.
If you’re actually riding your mtn bike in the mountains you’ll probably want the seat quite a bit lower. You’re probably going to be out of the saddle when you’re climbing and if you’re descending you want plenty of room for your legs to absorb the trails without the saddle hitting you in the @ss.
My mtn saddle post looks like it’s been through hell and back (paint all scratched up) because I adjust it according to what I’ll be doing each ride. That’s one of the big reasons for having the quick release on the saddle post.
I keep my post at the same height, common for XC. You wont see any in the pro XC field dropping their saddles for a descent. I you want to raise and lower a lot I would suggest a Crank Brothers/Maverick/Gravity dropper adjustable post.
I actually stand up when climbing a lot LESS than my road bike or tri bike (tri bike I don’t stand much at all either). especially on a full sus, but even on a hardtail, the suspension compresses a lot when climbing, it is easier to just go to a lower gear and spin up
