Moving Cassette
So, if I move my cassette from my race wheels to my training wheels do I have to adjust the derailleur? And if so how do I do that?
Shouldn’t have to, but if you did need a slight tweak it should only be a 1/4 to 1/2 turn (1 or 2 clicks) on the rear barrel adjuster.
Like Triuno83 said … shift your chain to the middle of the cassette on the new wheel. Get behind the bike and sight right down the chainline. The TOP pully of the drailleur should be aligned precisely with the cog on the cassette. If it’s off to the right, turn the barrel adjuster at the back of the rear derailleur counter-clockwise until it’s precisely aligned. If it’s off to the left … turn the barrel adjuster clockwise. After you’ve done this, check out all the gears, then come back to a middle gear and re-check it one more time.
Viewed from behind the bike, a counter-clockwise turn moves the drailleur pulleys towards the wheel. A clockwise turn moves them away from the wheel.
Small turns (a quarter of a turn or so) are usually all that will be necessary.
Thanks guys
You need to check the limit screws too, it’s really important. People shift into the spokes because they neglect to do this and the wheel might have a little different offset. Also, check the brake shoes so they are not rubbing the tire sidewall, that can be problematic…
One thing about swapping cassettes back to your race wheels- if your freehub body has a soft aluminum body (like every pair of Zipps I’ve owned), they will get the little notches in them from the cassette. When you go to put the cassette back on you may find it hard to get it all the way to the end of the freehub body. Don’t make the mistake I did once and force it- it will get stuck! A light filing of any raised bumps from the notches ahead of time will make re-installation a lot less painful.
It depends on the 2 wheels. I’ve gotten away with not having to adjust the RD, but sometimes a hub will be just a little off and I need to adjust the limit screws.
I’m seen plenty of wheels that needed no adjustment and others that needed a lot more than I would have liked. I’m planning to make a custom spacer for the one wheel I have that doesn’t match the others and still surprised no one sells them. A 10 speed cassette on a 9 speed hub takes a 1mm spacer. Why can’t someone make 1.1mm, 1.2mm, 1.3mm spacers. Then you could effectively have one spacer designated to each wheel and never need another adjustment.
I have more wheelsets than you can imagine and I swap them out constantly. And I swap out cassettes constantly. I’m always trying different race setups and switching things out between bikes. I’ve NEVER … NOT ONCE IN 15 YEARS had to touch a limit screw on my rear derailleur just because I swapped out a wheel or a cassette. I’ve also NEVER shifted a chain off into the spokes or into the seatstay or chainstay. Once the derailleur is properly installed and set up for one cassette, it’s always worked properly for all.
Maybe it’s just dumb luck for me … but with all the years, miles and wheel/cassette swaps, that’s hard to imagine.
I do find a quarter turn or two of the barrel adjuster can sometimes be required.
Has to be dumb luck for you. While I agree in theory with you about the limit screws, it’s just not always true. I borrowed my first set of race wheels this season for a local sprint, and 2 minutes into the bike leg shifted the chain onto the chain stay. (Swapped my cassette from a Mavic wheel onto a Rolf. Have NEVER had this happen before either.) Had to stop, grab my chain, and yank it back up onto the cassette. Fortunately it was not stuck. I think some wheels may have the cassette freehub body in a slightly different position.
Gosh, I see it happen all the time in races when people are swapping wheels areound and having shifting troubles or even shifting into the spokes. I have a problem maybe every 20th. time or so, though I don’t keep a tally on the garage wall. It takes 2 seconds to check and avoid shifting into the spokes so I just do it, sounds like you are lucky, so no worries.
