Not a newbie to the sport by any means, but definitely a newbie to doing my own mechanical work.
I’m on a 2015 Cervelo p3 that has the stock FSA Gossamer 52/36 172.5 BBright crankset. I want to move to 165 and in my simple mind I should be able to just replace the crank arms, but that may not be the case. What do I need to be taking into consideration from a mechanical standpoint to make the switch, ideally without completely changing the bottom bracket - but if I have to do that then I’ll go ahead and do that as well. Am I only able to look at FSA products? What else is compatible?
Making the switch due to hip/low back issues that are getting more and more difficult to keep in check with 5-10 minutes of stability work/day.
Thanks all. Another question, when I get on FSA’s website it looks like a lot of the 165 cranks come with 50 tooth chain rings, but I want to keep the 52 on there. When purchasing, does it matter what size chain ring comes on there - my assumption is I can just swap the 52 that I’ve got onto whatever else as long as it fits the bottom bracket but I don’t want to start into a process of ordering and sending back a bunch of product.
If it comes with a 50 it’s likely a compact (110bcd)
You would have to put a 52 with a 110bcd chainring (which are really common) on it.
From what you describe from your first post, the crankset you already have is a compact and those chainrings will likely work on a new FSA Gossamer compact.
