I have looked up some threads on valve extenders for tubular zipps - but still have a couple questions…
"Yes. As long as your tires are conti’s or Vittoria. You remove the core and insert the extender and then screw the core into the top of the extender. "
just got 404’s… have a new Vittoria Corsa Evo CX I want to mount… I think i understand that you take out the core, screw on the extender and then screw the core back on top of the extender - a couple ?:
- how do you remove the core without messing up the threads - tried it by hand and it didn’t come out
- is it recommended to put teflon tape or glue on all threads (where top and bottom of extender meet tire and core) - what kind of tape should be used?
- I have the tufo tape for mounting the tire - any pref. tape vs. glue?.. obviously it will be less messy - but i would think in the event of a flat during a race I would benefit from the layer of glue already being on the rim?? (these are used wheels so their is probably some glue on it already)
- maybe a dumb question - does it matter which direction this tire mounts - can’t really tell a difference…
Thanks!
