Most comfortable saddle
I’m pretty much talking to crowd of 170+ lbs…you lightweights can ride on a razor blade…those days are behind me.
I ride roadie almost exclusively and am thinking about trying some different saddles as my mileage is increasing a lot. At 6’1" and 185 lbs. I’m not big, but I’m not as skinny as the average multi sport guy. I need a little extra help padding my rump. I definitely sit on the saddle properly and don’t slide down on to my ‘taint’…I’m on my ischial tuberosity and don’t have pain per se, but after a couple of hours things get a bit noticeable, but not pain.
Any suggestions out there? I like the cut outs in many saddles today and have one now, but maybe a bit more rump cushion would be nice! Thanks
i am 175lbs and I can ride a razor blade type saddle on a road bike
its about fit, not padding.
you talking about TT saddle or road saddle?
I assume TT, in which case I’d look into saddles with a cutout, or an adamo
Adamo Typhoon or Century. Solved all my saddle issues.
THANKS! All my dang life I have wondered why I never saw any saddles get wider at the point where this gets wider, but rather most go narrower. Once again, I’m late to the ‘idea party’, but at least my butt will feel a little better at the 3 hour mark with that width…thanks!
Fiziks Airione.
I tried the about 1/2 a dozen saddles before this one and have stuck with it for years.
Fiziks Airione.
Yea I tried several of the Fiziks, but just didn’t work for my bod. Sat on a Koobi of some sort day before yesterday and it was magic, but wanted to see what else was out there before buying one. Thanks for all the input everyone…thank goodness there are a lot of different makes and models out there!
I have had good luck with an older model called a Rols and the Sele Itialia flight saddle, both are kind ogf old school. I have a leather saddle (a swallow knockoff called a Cardiff http://www.cardiffltd.com/cambria.html) on my winter bike and I’m getting to like it also, but it weighs about 3 tons.
There is no such thing as one most comfortable saddle for all. Everyone’s bottom is sized and shaped differently, and one person sits on the saddle differently than the next. Specialized has noted this with their varying saddle widths in their new line. The key seems to be to put most of the riders’ weight on the ischial tuberosity, as you have noted, and to have a small amount of weight supported by the adjoining area. Since you don’t mention any sort of “taint” issue we can probably assume you ride correctly on your saddle, and the cutout type saddles may not be necessary for you but they may be preventing any issues in that area from arising. (no pun intended). It has taken me many many years to find out what I need in a saddle, at least one bout of prostatitis, and a lot of chafe. For me, the smaller the saddle the better. I’m very little and my bottom area is little, too. So the smallest saddles fit my bottom area properly. There is no “sizing chart” or standard measurements for saddles of which I am aware, which compounds the problem. I found my proper saddle quite by accident. I was building up a 14 pound bike and chose the 135 gram Selle SLR based on weight alone. I didn’t think I was going to be able to ride it, but it fit perfectly! It was the first time I felt absolute comfort on a bike, and it was on a “razor” as you call them. I’m now much older, and treat my body a bit more tenderly, so I’m on the Selle SLK w/ cutout (after prostatitis struck me). Just yesterday the cover tore after 2 years so I was researching saddles yesterday. The SLC Gel Flow is about 10mm narrower than the SLK, and I think that would benefit me and my tiny little ass.
Mileage wise, I was riding 400+ miles per week in June with back to back centuries on Sat and Sun. About half that at present. All road bike riding.
You’re just going to have to keep experimenting, would be my two cents worth. Might glean some helpful info here, maybe not.
Thanks I’m actively looking. I agree, to say anyone should be able to ride any saddle with the same comfort is quite ridiculous. It’s analogous to saying everyone can wear size 8 shoes or waist 30 underwear…yea I could if I had to, but I don’t b/c I realize there are a million options out there to choose from:)
I remember when I was 145 lbs. and rode a Flite Ti b/c it looked cool…hurt after an hour, but damn it looked cool! Then when I started training for The ‘91’ Great Floridian I switched to a Brooks Gel Lite and realized long rides could be fun!
just got one of the new Cobb V-Flow Max saddles. I’m only 50 odd miles on it, but so far it’s the most comfortable saddle I’ve ever tried (about 15 years of cycling “trial and error” approach to testing), I’m just coming off a Arione that wasn’t really bad, but definitely wasn’t good, before that a Tri-Stryke.
It’s kind of funky looking, especially with the slightly nose-high adjustment Cobb recommends, but you can’t see it when you’re on it and it’s definitely comfortable.
