Anyone* care to explain the difference between these two terms, and provide an example of how the addition of just one simple word - i.e., “work” - can make a significant difference?
*Paulo, consider this one of the questions on your PhD qualifying exam.
“Anaerobic work capacity is defined as the maximum amount of work that can be produced from anaerobic energy systems (Green, 1994).”
Anaerobic capacity is, you know, like that dude that’s a really fast sprinter, wow, he’s got, you know, like a really big anaerobic capacity… you know…
Now you’re 0 for 2.
No, it was a play on words: I wrote “moron” intead of “more on” because some people get bored with discussing terminology.
I’d answer that “anaerobic capacity” is NOT a moron term.
It’s definitely not. However, it also isn’t precisely the same as “anaerobic work capacity”.
Apart from that, what good would any comment/interpretation do?
It would give people like Paulo the opportunity to show what they know (or, apparently, don’t know), as well as help illustrate the importance of the use of precise terminology.
And this is not a good question for an exam to begin with. Extremely muddy and out of context.
It wouldn’t be “extremely muddy and out of context” for someone pursuing a PhD in exercise physiology (hence my wisecrack about seeing it on a qualifying exam).
I hope you are not teaching!?
In this case, all I did was ask a question. Now, are you going to take a stab at it, or not?
Andrew, are you developing a glossary? If so, great.
Love the “mor-on” play on words. I do enjoy your posts; also those of the other significant contributor. (More on “More is More” always welcome.)
Consider the following scenario: you have a subject exercise as long as they can at a power (or pace) that elicits 100% of VO2max. They then pursue a program of high intensity intervals for a few weeks, which enables them to continue longer at that same intensity (power or pace at VO2max not having changed). By definition, their anaerobic work capacity has improved, but their anaerobic capacity has not.
Is the definition for anaerobic capacity because it’s “from anaerobic energy systems”.
So a definition for anaerobic work capacity could be:
Anaerobic work capacity is defined as the maximum amount of work that can be produced while engaging anaerobic energy systems at its full capacities (Paulo, 2007)."
It’s certainly closer to anaerobic capacity, anyway.
Anaerobic work capacity is the maximum amount of work that can be performed during exercise above critical power before fatigue occurs (and hence despite the name, can actually be partially aerobic in nature…as my example was meant to illustrate). OTOH, I would define anaerobic capacity as the maximum amount of energy (in terms of, e.g., moles of ATP) that can be produced via the anaerobic energy pathways before fatigue occurs.
To put it another way: anaerobic work capacity is a functional measurement, i.e., it is based upon performance testing. Anaerobic capacity, OTOH, is really a physiological concept, and although there are ways of estimating it (e.g., maximal accumulated O2 deficit), can’t really be measured directly.
can’t we put an end to all of this and just s/b/r? sometimes long and slow, sometimes short and fast, sometimes medium, as much as we can handle?
Don’t forget to work on your muscular endurance and strength endurance as well.
my exercise phys book has something about anaerobic capacity in relation to the Wingate Cycle Ergometer Test: anaerobic capacity is the total work accomplished over 30 seconds of supermaximal exercise.
edit - the book doesn’t say anything about anaerobic WORK capacity.
