I’ve had wheel wiggle on downhills that approach and exceed 28 mph. the front end gets very nervous. At first I thought it was the hub…had it checked they were ok and the wheel is sound. the next thought is that the stem and bars put me to far over the front hub? or the rake of the fork maybe wrong for the frame. when I first bought the bike I had many mechanical problems and had it completely rebuilt by another shop. It’s a litespeed tachyon I bought in 1997? I’ve been out of the tri scence for many years, just dusted my bike and body off this july and off to the races again. any thoughts? I do plan on going to a f.i.s.t. fitting in jan. My hope is the frame is good and I can upgrade parts.
High speed wobble can sometimes be caused by not having enough weight on the front wheel. Try shifting your weight forward a little on the downhills. When you see the pros sitting on thair top tubes it’s as much for stability as it is aerodynamics.
It may be that your front skewer isn’t tight enough. I just competed in my first TT today and experienced some crazy wheel vibrations about 1 KM in. I slowed down (difficult when the brakes can’t find the wheel!) and then started again and didn’t experience the problem fro the rest of the course. Afterwards I asked my coach and he reached right down to my wheel and showed me that it had about 1 inch of travel in either direction. Rookie mistake (didn’t tighten enough after my last flat tire).
Just my 2 cents…
