More field vs. roller Crr data
Tested some Michelin Pro Race 2 tires this weekend…next up are some of the new Bontrager Race X Lite Aero TT tires (the ones shown below were purchased in May of last year, and weighed 195-200 g).
http://i32.tinypic.com/1z6e2z6.png
But, but,…don’t you understand that rollers can’t possibly reflect “real world” rolling resistance??
Yeah, I think you’re pretty much narrowing in on your personal test road Crr multiplication factor :slight_smile:
Thank you. I got one the other day and put it on a S60. I think someone was asking how it lined up with that wheel so if anybody wants me to take a picture let me know.
:slight_smile:
Right, it’s definitely road-surface (and weather conditions) dependent (with the road in this case having been freshly paved ~5 y ago).
We put a set of the Bonty’s on Zipp 808s…23 rear and 19 (or 21?) on the front. The front lined up very nicely with the rim profile. The rear was a little fatter, but the wings lined up really well with the rim. They were not too difficult to get on either. And, they rode really well.
can you elaborate on what the “VF Record/Vred. Fortezza TriComp” notation means? Is that a front/rear pair? Thx.
Correct.
Correct.
So…the next question is, how does that “on road” number compare to the weighted average of the two tire’s Crr from Al’s data?
edit: Oh wait…that’s what the above chart shows…so, did you assume a 50/50 split or a weighted average based on your actual front/rear weight distribution?
How was it you were able to factor out aerodynamics of the tire? and the rim interface?
ie. did the Bontrager test so well partly due to better aerodynamics?
and on another note, I’d like to see you pick one of the tires in question and check it’s crr on that same stretch of road at a variety of tire pressures. I know that everyone can demonstrate a dozen different ways why the bumpy roller test is perfectly valid, but I don’t believe I’ve seen it replicated on a road test using good methodology.
Correct.
You can slice it various ways, but I calculated the average from Al’s data as (0.00360+0.00234)/2.
Correct.
Coolio…
Actually…and AFM will be the first to admit this, but the “bumpy” roller tests he has data from ARE NOT likely valid. This is due to a couple of issues, the largest of which (IMHO) being that his “bumps” were only applied to one of two rollers on the rear tire. That’s going to obviously shift the “breakpoint pressure” (i.e. the pressure where the Crr starts increasing) much higher than it would be in the “real world”.
It’s the smooth roller tests that AC is comparing his “on road” values.
If you want to see a representative plot of Crr vs. tire pressure on a “real road”, search for some of my posts where I showed the plot of that for a pair of Vittoria Open Corsa KS tires. Search on “Crr” and “pressure” and my username.
BTW, AC typically does a “regression” style field test, and so the Crr and CdA are both estimated. The better aerodynamics of the Bonty Aero tire will show as a lower CdA and not effect the Crr.
At least in theory, the regression approach allows you separate sources of resistance that are linear with respect to speed (i.e., rolling resistance*) from those that are non-linear with respect to speed (i.e., aerodynamic drag).
*It should be noted that while it is widely assumed that rolling resistance is linear with speed - such that Crr is speed-independent - that might not be strictly true. Furthermore, what the regression approach provides is really a “global coefficient of friction” (as Jim Martin referred to it) that includes any source of resistance that has a linear component.
See above (and also note that the Bontrager didn’t do any better than expected, at least once you consider their mass/date of manufacture).
Tom has already done this, so the only way I’d ever get around to doing such testing is if I were attempting to optimize the pressure to use on that particular surface (e.g., a particular track).
More interesting to me would to perform similar experiments on a really rough road, just to get a better feel for how much Crr changes with pavement quality.
With CdA of course being the primary interest, i.e., the Crr data are really just a side benefit. (And in fact in this case I was explicitly testing something else, but used wheels shod with PR2s just to get another data point.)
I’d like to see this. Seems like virtually all FL road races are in the sticks, and the pavement quality is usually horrendous. That alone is one factor that makes me pick tubulars for a lot of races as I’ve seen a lot of pinch flatted clinchers and experienced a couple…I’m not the lightest guy around. :slight_smile:
