I decided to start monitoring my HR while I slept and then loading up the chart the following day in a way that allows me to compare it. It also is helpful for determining how long I slept.
I’ve done this two nights in a row. I am guessing that I can possibly assess my sleep quality with this method and monitor my adaptation to altitude.
Anyone else ever try this? Are there patterns to look out for?
if you do it consistently it could be used as a great indicator of stress factors in your life or environment. as you mention adaptation to altitude… what elevation are you at? just don’t stress out about always doing this test with the monitoring device. i use a simple TANITA digi heart rate finger tip reader nearly every morning as an indicator…
I do this every few months or so when I think of it. I usually will get up very early, put my heart rate strap on and go back to sleep while my watch records whats going on. I have used the concept of minimum sleeping heart rate (MSR) to monitor my recovery, etc. This is just a BS term I made up but I think its a valid way of checking in on your state of training. I think the lowest I ever record was a 37 or 38. My only question is what should this properly be called? Is it my MSH, or really just my resting heart rate even though I’m not at “rest” but actually sleeping.
Cool - I have the same idea. In the morning I open it up and look for the minimum and the average. I can see higher numbers as I have incremented up altitude or done a hard workout.
"My only question is what should this properly be called? Is it my MSH, or really just my resting heart rate even though I’m not at “rest” but actually sleeping. "
I’d like to know the anwer to this question as well. Anybody?
Heart rate variability does not measure the heart rate per se. It is the variability in the interval between beats. You need a monitor that records the interval between every beat. Most do not do that. WIth the Polar S810, I could see exactly how long between beats and calculate various parameters. Heart rate variability has been linked to depression, effectiveness of certain therapies, stress, heart disease etc… More variability is good. It means that your heart rate is rising and falling with your inspiration/expiration cycle. Stress (and adrenaline hormone release) decreases heart rate variability. If you could measure it through the night, it might tell you something about recovery. I don’t think those studies have been done yet though. Seems like I read something about HRV following a marathon. Might be interesting to look at HRV after an Ironman in relation to some other physiological and psychological parameters. Anyway, you can’t get that info with the HRM you have anyway…
I think that the device captures - or could capture it with a firmware upgrade - the data necessary to do that, but the software - either the native Garmin software or motionbased -does not.
I believe I am getting SOME useful information, but will consider some way of capturing HRV.
I’ve done that, it was interesting (used a lot of battery), but after a few nights I got bored with it. What is really fun though is recording HR during sex…
“What is really fun though is recording HR during sex… ;-)”
Dude who in their right mind leaves a HRM on during sex?
Nevermind I forgot for a second this is a tri forum none of us are in our right minds. We joke around at the LBS about this did you actually do it? If so haw far does your HR drop off at “completion.” After all orgasms are known as “the little deaths”
HR went back to ‘normal’ resting rate at about the same speed as it would at the end of a tempo run. I’d have to do more testing but it seems to me that while the excitement increases HR some, the biggest impact comes from the technique used. For example (for a guy), aggressive doggie-style will create a higher HR than standard cow-girl (independent of orgasm). The problem is that there is a delayed response if you’re with a woman who has frequent relatively quickly obtained orgasms from hard/fast ‘interval’ style sex (mixed with slower build periods). You’d need some kind of power meter to accurately measure that. IIRC, the day I wore the HR monitor we had more of a quicky tempo session without much of a warmup or cooldown. I’ll look for the file and see if I can post it. Maybe on a new thread? Don’t want to hijack this one…
while the excitement increases HR some, the biggest impact comes from the technique used. For example (for a guy), aggressive doggie-style will create a higher HR than standard cow-girl (independent of orgasm). The problem is that there is a delayed response if you’re with a woman who has frequent relatively quickly obtained orgasms from hard/fast ‘interval’ style sex (mixed with slower build periods). You’d need some kind of power meter to accurately measure that."
When I am seriously training I’ve done the exact same thing. Even have a specific data entry point for it in the analog training log I’ve been keeping for years. Very useful, for me, to see if I’m getting enough rest; getting sick, etc. I really should get back into doing this again. I do the same thing as you–just get up a little early and put on the strap; start the monitor; and go back to sleep. Then when I wake up at the normal time I have my resting/sleeping data and I’ve not burned up 8 hours of HR monitor battery time.
