I am looking down the line and want to try a straight extension aerobar this year. What is the most frugal (cheapest) way to obtain a suitable 22.2mm tube/bar? Are the outside diameters of MTB bars 22.2mm? I know that MTBs typically have 25.4mm center sectiosn. DO they have 22.2mm outside sections? I do not want to cut the bars I have unless there is no alternative.
Tubing supply vendors. 7/8" is typically close enough. Get 7005. You may also be able to get some for free from Alcoa if you ask nice. For trial runs, 7/8 PVC pipe is more than adequate for fit set up and should cost you all of $1.79 at your favorite Home Depot.
