WARNING: semi-rhetorical navel-gazing below!
A semi-random post spurred by various things (listed in no particular order, except for perhaps the last):
an off-hand comment by Gerard about CdA at 0 deg of yaw being dominated by frontal area;
the results of wind tunnel tests I/we have performed at TAMU comparing:
A. the Superman vs. a standard aero position
B. Blackwell vs Zipp wheels
C. the effects of 75 vs. 80 cm of reach
D. the effects of cardboard fairings added to an aero helmet (don’t know if I’ve posted these results)
which clearly demonstrated that what happens at 0 deg of yaw rarely tells the full story;
the fact that only once have I measured an iron-clad difference in CdA using the field test approach (which happened to result from changing tires);
the fact that my CdA back-calculated from TTs performed in non-still air is invariably lower than that measured in formal field tests conducted under still-air conditions (i.e., at/near 0 deg of yaw); and finally
the results of some field tests performed by an elite athlete that I just had the opportunity to analyze.
Given the above, I have to ask: is field testing to measure CdA (which, to obtain truly precise results, must be performed when there is very little wind) really worth it?
