Mission Skin Care
Anyone using their anti-friction cream? Opinions? Has full page ads in the mags and big name endorsements
I used it and found it to be very nice. I thought it was pricey for the volume, but I also found that a little went a long way and that it worked very well. I’m always up to try new chamois butters, and this one was pretty good. Not good enough that I became a total convert or anything, but I certainly would say if you are thinking about it then try it. You may love it. At the very least, it is absolutely a solid product. I bought mine at Performance; one of those impulse buys when I was in there getting some bike cleaning stuff…
Never used it but looks pretty interesting and they are definitely putting some huge $$$ into the marketing. Have used the glide stuff between my legs on runs and it is crap…seems to make your inner thighs more sticky than more slippery. That being said I use the glide on my neck to avoid wetsuit rashes and it works great!!! Just as a reference, I am 6’3" 190, so I don’t have too much friction, but on runs over 20 miles I tend to get some chaffing. The best stuff on the planet is the ceramic stuff by Asics. I am sure other companies make it too, but the asics stuff is what I have. It has a foam applicator on the top with a little hole in the foam. You squeeze the goo out of the hole onto the foam(so you don’t get any on your hands) and rub it in between your legs. Then you leave you legs separated so that the ceramic goo can dry out…about 60 seconds. Once its dried, it is on there for good, or until you wash with soap. The ceramic goo dries out completely leaving no residue or stickiness and allows your thighs to just slide right by each other…AMAZING STUFF!!!
