Mirrored pools?
Just read the article on endless pools.
I’m not a big fan of the concept, but I do like the idea of having a mirror on the bottom to check out your stroke in real time.
Anyone ever see this concept applied in a real pool? If not, is there a simple way to do it?
I just took the one off my bedroom ceiling.
I’ve got a great idea for the Endless pools engineers.
It would be called, “The Endless Pool” with “Roving Ass Beater.”
It involves placing on each side of the pool, two heavy arm like, cranes, with pads, and, on their ends are big rubber hands, or weighted pads, and every three to four seconds, they come down hard on the swimmer—roving back and forth down the small pool, providing a vicious beating on the swimmer. The “roving beater” would make sure the swimmer gets hit in the head, shoulders, back, back thighs, and feet. You could however set up the device to just “beat” the feet, or back or head. Whatever you need to work on. You could also remove the outer pads, and go “raw,” by adding small plastic pieces to mimic long fingernails.
Finally, we can have something to mimic the open water swims, those ridiculous intervals don’t provide in the pool. Oh, yeah, you’d be ready for the open water swim.
http://www.altcountrytab.com/modules/Forums/images/avatars/149437201440672445cdfea.gif
$89.95 http://www.kiefer.com/Kiefer/productr.asp?pf_id=800046&gift=False&HSLB=False&mscssid=0502BF54A962248EA9D39AF762FA9E5F
STP, thanks for the link. That is most cool.
Now how do I convince the YMCA that they need to buy about 20 of them? :slight_smile:
I used to work there and pleaded with them to change the position of the mirror. They don’t get it. The pool is ok but as I said before you don’t really get a good pull of water in the EP.
