Michigan Winter Running Jacket
I need a good jacket for running in Michigan Winters. When it turns frigid out I turn to the treadmill but will venture out as long as it stays above zero. The run this morning was cold enough for a jacket but the one I have doesn’t breath and by the end of the run I was soaking wet with sweat. I live in a very rural area so visibility is very important. $100-$200? Has anyone used the Brooks NightLife Jacket? Thanks
Sugoi Invertor around $120 if you search. This thing is really verstile from 0 to 40 you can use it.
Later
Anything made from Gore N2S material, its an amazingly warm, wicking, windstopper fabric that is superb as a single layer to temperatures well below you would expect.
I’m sure a search posts on it will give you more anecdotal info.
