This is not about rolling resistance. I am not fast enough for that to matter. I have used the Michelins for 4 years. I love their grip, performance and puncture resistance. My new bike has the Bontragers and I know nothing about them. Thanks Kenney
I would recommend replacing them as soon as you are able to unless you like flats. The set that came on my road bike did not last 500 miles before they had to be replaced.
The Michelin Pro Race 2 really are the best choice for exactly the reason you mention. Really one of the easiest gear decisions you can make assuming you use clinchers.
Over on the H3 H3C thread their is a post saying the Bontrager on the H3 was a favored set-up in some test. First time I read that bit of info.
Are these the tires that have the exact same writing on them as the Continential Supersonic? “Made in Germany” yadda yadda yadda
Humm - I didn’t like mine.
jaretj
They’re fast, but I’ve had a couple of sidewalls blow. I’d just ride them until they fail, then get some new Michelins.
The ones being discussed in that thread are the Race X Lite Aero tires.
Not sure of what the differences are, but different tires than this poster is talking about.
I also had a sidewall blow out on the race x lite’s
It seems to be the general consensus, here and elsewhere, and there is also test data to back this up, that the Michelin Pro Race tire is just about the best choice you can make in this area.
I’m a michelin fan. Last spring I got a bike with the bontragers. No problems. Rear wore a hole after 2000 miles. I bought a new one to replace it so it would match the front. A little cheaper than michelins.
I ride Bonty Race Lites. No problems through 3 seasons and two rear tires. Dont have much to compare them to, though. Next set I will try the Michelin’s just to see how they measure up. I’ve had 2 flats in these three seasons, no sidewall issues, no blowouts. One flat was a glass puncture, the other was a snake bike after a HARD pothole hit.
