Michelin Pro Race vs Mich. Ironman Clinchers
Anybody know the difference between the Michelin Pro Race Clinchers and the Michelin IronMan clinchers? Is it a marketing ploy? Weight and PSI are listed as the same? Why is the Michelin PSI only 110 and other clinchers are 125, 135, 150 etc. Are Conti’s a better choice? I did have a blow out previously after riding about 80 miles in 90 weather and surmise that was due to the tube expanding due to the miles and hot weather, but may be in left field.
I plan on using these tire at IRONMAN NZ if the road difference matters.
I know tubulars are better than sliced bread and when I get a set of high end racing wheels to replace my Real Design Supersonics they will be tubular wheels.
Thanx,
Barefoot
From what I have seen they are the same tires.
Fleck
I believe they are the same tires, different colors. I have some of each and can’t tell the difference. They ride great, last a long time, and are super wet or dry.I am fairly competetive and notice almost no difference between them and the continental tubulars I used to ride except I don’t have to prestretch and glue them. A good article on tire pressure can be found on the Nimble wheels website. Those guys are honest and make some killer fast wheels. The info I have received from them and HED has been right on and is pretty much different from what you read elsewhere. I got a set of Maxxis Hors Catagorie tires for free with a set of HED 3’s I bought from all3 sports in Atlanta. They are made here in the USA, are about $15 less than Michelin and I cannot tell the difference between the two and they come in both 650c and 700. They can be inflated to 128psi ,I believe. They even look just like Michelins. They have been great for me so far. I have tried alot of combinations and don’t see any improvement with the tires inflated over 130psi. Hope this helps.
Same tire, one has the M dot on it and has red stripes. 110 in that clincher is all that you need, any more just gives you a harsher ride and the same rolling resistance.
Conti Grand Prix’s are good tires too. When you get to this level of tires, personal preference is what makes the final decision. My personal preference is the Michelin tires.
jaretj
‘same shit, different pile’ i believe is the expression…
however, they aren’t exactly ‘shit’.
I love them, i’ve used both the pro race as well as the IM tyres, just a matter of color choices. I think currently i have about 4 pair lying around that i bought on special, all different colors. Just a matter of finding them cheaply and stocking up.
as for the 110, does feel a little soft sometimes as compared to riding say my training tyre @ 130, but i’ve run them @ both 1/2 IM’s and IM’s with no problems, and the comfort is great. I some of the top pros use them and have no problems either.
enjoy!
Here is another option: Lucero came with Vittoria Rubino Pro Slick and I can use them as race tires. I also have a pair of Vreestein Fortezzas that I can use as race or training tires.
The cheapest price I’ve found on the Mich. Ironman’s are $39 but Performance has the Violet Pro Race for $19.99 ea. I’m not big on colors, but not sure purple tires is worth saving $40.
Nimble’s web site does have a good article on tire pressure.
Thanks,
Barefoot
funny you should mention the purple…i bought a pair.
they retail @ stores for 98 cdn each. So @ 30bucks each, i decided color isn’t huge. I can always take the felt marker to them.
As for the rubino pro’s, that is what i currently train on. I LOVE them, they are great for training tyres, there is just something about the michelins i prefer for race tyres.
I started using the Michelin IM tires last summer and am under the impression that they have some puncture resistant feature that is lacking in the Pro Race tires. Anybody else believe this or just my good luck?
Now that you know there are the same tire, I would advice against them. In my experience (4 tires total), the Michelins get cut up very quickly and I didn’t get a great deal of mileage out of them either. Conti GP 3000 will give you the most mileage, and I’ve been dying to try the Attack/Force set. Either of these are an option at the same price point.
For an extra $10, I’ve been extremely pleased with my Vittoria Open Corsa CX’s (going on 8 of these in a row). They’re basically a tubular tire that was cut down the middle and they added a bead. They are a very round tire that corners much better than anything I’ve ridden (other than tubulars), especially when wet. The difference in feel between this tire and a tubular is very small. Because of the roundness, they are rated at 130 psi and they ride much more comfortably than the michelins even at that pressure.
How are they to put on compared to the Michelins? I’ve used Conti 3000s 20mm and they were a bear to put on. Not sure I need a 20 mm, and will probablt stick with the 23 mm tires.
Barefoot
Conti’s are usually a lot tighter than most, but the vittorias are about as easy as the michelins. This aslo depends a lot of the rim. matrix rims + conti tire is near impossible. Go with a 23 for more comfort unless you are super concerned with aero.
FYI - performancebike.com has Michelin Pro’s on sale for real cheap right now.
