I had something very similar, less burning though and more tightness. Went through just about everything and tried every diagnosis from every doctor (other than the RSD Frank Day mentioned, I have heard him mention that before and wondered if that could be what I am dealing with, although I don’t really understand what it is.)
I do have a compression fracture at my L3 vertebrae though so there is a back issue with me. However, 3 orthopedists, 3 rounds of bloodwork, multiple MRIs on the back and legs, that not-so-fun Nerve Conduction Test all showed nothing abnormal.
So a lot of patience and even more stretching has finally got me back running again, that’s about all I can tell you. Kind of frustrating to have dealt with this for 6+ months with no real conclusion, but I am running again so I am happy about that.
Like I said, Frank Day’s suggestion does make me wonder and I don’t recall a doctor ever bringing that up, at this point I am just so burnt out on doctor’s after way to many appointments.
Most docs don’t have a clue regarding RSD. In my practice it was the most common missed diagnosis when people came to me. The problem is the text books only describe the worst condition, when people have withered hands and are totally debilitated. Unfortunately, RSD comprises a spectrum so those with “lesser” disorders usually go undiagnosed and labeled as it being “all in their head” since they can’t find ANYTHING.
The key words that patients would use to describe their problem that raised my suspicion were “burning”, “hot”, “tightness”, “sensitive”, and “continuous”. Also, if the distribution of the pain didn’t follow any normal known nerve patterns suspicion should be raised.
RSD is simply a disorder of the nervous feedback system and somehow the sympathetic nervous system is involved. When you hit your thumb with a hammer you feel this burning pain. That is normal. When it doesn’t go away, that is not normal and that is RSD. RSD is set off by some trauma, although it does not have to be major, stubbing your toe can be sufficient. A related disorder is post-herpetic neuralgia (shingles).
It is “easy” to diagnose because a sympathetic block to the area makes all of the symptoms go away completely, at least for the period the block is present. In my experience in about 50% of those who get this diagnostic block, the block is also therapeutic and when the block wears off the problem is better and a small series of three blocks cures the problem. Of those who don’t respond easily about 50% of them can be cured with more prolonged or aggressive treatment and the remaining people tend to be much more difficult to cure, although the pain can usually be minimized. those who had “mild” symptoms tended to be easier to treat than those with severe symptoms. Thermography is a non-invasive test that can also be used to confirm suspicion (although it cannot confirm or “make” the diagnosis) as many times there is usually temperature changes in the area, usually cooler than the other side but it can be hotter. Normal temperatures does not exclude the diagnosis however.
You need to find a doctor experienced with giving sympathetic blocks and treating RSD. Most of these are going to be anesthesiologists and anesthesiologist pain specialists.
